Engine Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hennessy3300, Apr 3, 2020.
  1. Apr 3, 2020 at 5:16 AM
    hennessy3300
    hennessy3300 [OP] Well-Known Member
    My 2005 4.0 with 150k miles was diagnosed with a stretched timing chain. it is intermittently throwing a p0016 code but still drives great. I was quoted 3200$ to repair it. The truck is in awesome shape and I've put a ton of upgrades into it so I really don't want to get rid of it. Should I repair it or try to find a low mileage donor motor. If I decide to replace the motor I will drive this one until it blows up. Who knows I may get another 100k out of it. If I repair it, I will have them keep going and replace the head gaskets also since they are prone to failure on my year and around my mileage. What year engines are compatible with my year if i decide to just replace the engine?
  2. Apr 3, 2020 at 5:56 AM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    I'd get a second opinion. That seems exceptionally odd at only 150K miles.
    NYCTaco52 likes this.
  3. Apr 3, 2020 at 6:07 AM
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    If you are locked in the house, take the time to view these videos to give you a full understanding of 4.0 engine timing chain issues. This guy is beyond a technician.
    https://youtu.be/il9iR095teM
    420taco, lynyrd3, Alexely999 and 5 others like this.
  4. Apr 3, 2020 at 5:24 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Chain replacement is scheduled for 225 or 250k. I'd be looking elsewhere for the problem
    OldManTacoFeels likes this.
  5. Apr 4, 2020 at 7:35 AM
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    Seems way too soon, & price seems like a dealership price. Like said, a second opinion & maybe a third. How disappointed would everyone be with $3200 in repairs on a 150K Taco. Strange things happen
    OldManTacoFeels and Larzzzz like this.
  6. Apr 4, 2020 at 12:38 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Get a second opinion.
  7. Apr 4, 2020 at 3:02 PM
    Hooligans
    Hooligans Well-Known Member
    Fairbanks, Alaska
    2015 4x4 2.7/5spd.
    Still thinking about it.
    Have you had it a long time? If in fact the chain is worn out then could it have been abused or not maintained properly in the past? I'm in favor of repairing the original engine as opposed to replacing it with another used one. Maybe you could send an oil sample in to get a sense of the overall health of the thing.
    Kolter45 likes this.
  8. Apr 6, 2020 at 2:42 PM
    hennessy3300
    I've owned it about a year an a half. I assume the original owner didn't keep up with the oil changes. It runs awesome and only throws a p0016 code when it is really cold out and I don't let it warm up, never comes on other than in the winter months. I'm doing oil changes every 3-4k with full synthetic oil to try and delay replacing it for a while. When the time comes, I will most likely just rebuild this engine. I may tear into it myself and save $$$ I used to build drag engines for mustangs back in the 90's. This engine doesn't look too difficult.
  9. Apr 6, 2020 at 2:51 PM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    $3200 sounds about right.. if you subtract $2000 from it... That's way overpriced and should be the last resort once you've exhausted all other options to rectify the issue.
  10. Apr 6, 2020 at 2:54 PM
    hennessy3300
    $3200 quote was from a local toyota stealership
    Alexely999 likes this.
  11. Apr 6, 2020 at 5:38 PM
    rphillips
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    Yes, sounds right for a dealer, that's why you try to never go to a dealer. Dealers are also known for selling things that aren't needed, not say'in you don't need a timing chain, just say'in it would be really uncommon to need one on a Taco at 150K. Did anyone happen to mention a second opinion & not from another Toyota dealer?
  12. Apr 6, 2020 at 5:41 PM
    Bishop84
    Bishop84 Well-Known Member
    It is very expensive due to parts alone.
    It's 3 timing chains and 3 tensioners, sometimes guides and idler plus about 8 hours labour.
    Add a water pump, gaskets and fluids and it pops up to 3k no problem.
    p0016 is very common at 150k + and this will fix it.
    b_r_o likes this.
  13. Apr 10, 2020 at 1:09 PM
    rphillips
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    Hey henessy, any updates? I been doing a lot of reading & searching & not finding these Toyota problems at 150K. With timing belts, maybe, but not with the timing chains. Really interesting. Please keep us updated.
  14. Apr 11, 2020 at 4:10 AM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    The timing chain stretching at 150k is highly unlikely. Most people never have yo replace them. Hell I gave had 40 year old cars with original chains.
  15. Apr 11, 2020 at 3:47 PM
    rphillips
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    8 hr. labor @ $100.00 = $800.00 labor. Hard to imagine even a dealer could charge $2400.00 for parts to change the timing chains. I just punched it up on ebay. Toyota 4.0 v6 eng rebuild kit. Pistons, rings, wrist pins & clips, main & rod bearings, timing chains, timing gears, 3 tensioners, guides, water pump, oil pump, gasket set...$365.00 + free S/H. Sure, it ain't OEM Toyota, but that price.
    UOFan likes this.
  16. Apr 11, 2020 at 3:54 PM
    hennessy3300
    Anyone know a good shop in NH / MA? 2 shops have said they'd quote the job and never called me back.
  17. Apr 11, 2020 at 5:08 PM
    craigs1
    craigs1 Well-Known Member
    2007 4Runner Limited, 4.0L
    High quality no doubt. Only the best recycled brake rotors and Coke cans, and some kid in China forging it all with a pack of matches and a butterknife.
    420taco and Hooligans like this.
  18. Apr 11, 2020 at 5:10 PM
    hennessy3300
    I definitely would go oem or at least melling or cloyes for timing components. No ebay junk.
    b_r_o likes this.
  19. Apr 11, 2020 at 5:26 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Let us know how the rebuild goes with those cheap ass parts. Eeeeh! Is there even a scheduled t chain replacement interval in the owners manual?
  20. Apr 11, 2020 at 9:30 PM
    Slum Lord
    Slum Lord Well-Known Member
    Sounds a bit high but with a dealer you are getting OEM quality parts with factory trained technicians.
    I'd personally look for an independent Jap or Toyota specialist and use OEM parts bought online. Do head gaskets while you are in there. Might was well if you are that far along with all the cooling stuff.
    Or
    Sell it and buy something newer. That's a pretty expensive job and will be a significant chunk of the truck cost. Consider trading it in if you can't do this work yourself.
