Engine randomly dies... HELP ?!?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BudTRD, Feb 1, 2013.
  1. Feb 1, 2013 at 12:52 PM
    BudTRD
    BudTRD [OP] Active Member
    Brian
    California
    Toytec 3" coilover , Camburg uniball UCA's , Maxtrac 4" spindles, steel braided lines, doug thorley short headers, spintech muffler, AFE cold air intake stage 1 , Jet performance throttle body spacer , billet grill painted black, cleared out headlights with HID bulbs.
    So i noticed a couple weeks ago when i was merging off the freeway my truck stuttered and threw a check engine light and felt like a misfire, only lasted a secind then it was fine.
    few days later i was just driving down the road 45mph not accelerarting and it loss power for about 1/2 a second 2 or 3 times in a row so i immidiately pull over, pop the hood and look for loose cables, leaking , weird noises. i found nothing, and it seemed to been running fine at that point, unltil i slammed the hood shut then it died . it fired right up and drove fine for another couple weeks.
    last night when i parked i was sitting in my truck letting it run and it died. i started it back up no problem and it kept dying after 3-5 seconds. so i started it once more glassed it a bunch to try to maybe clear it out and it seemed to be ok, so i went to drive off and as soon as i turn out into the busy street it completely dies again and i almost got nailed by a few cars in the process. i called AAA and waited for them to arrive, but of course when they got there it was running perfect again and he suggested my idle censor might be bad . i drove it home without a hitch, and drove to work today again with no issues at all.
    i am at a loss on this one, i can usually figure out problems by process of elimination but this time its so random that i cant re create the problem.
    any ideas>? its a 2007 TRD 4.0 2wd with 100k miles . havent done anything to it as far as aftermarket stuff yet. although in a week or so im going to be installing new headers, o2 censors, cold air intake, oil change and after reading up on it, i am going to try the sea foam out.
  2. Feb 1, 2013 at 12:59 PM
    Ryan DCFS
    Ryan DCFS Elevator guy
    East Bay Area
    09 DC long bed TRD silver streak
    Any trouble codes?
  3. Feb 1, 2013 at 1:09 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    you need to figure out what that cel was for. it should be stored
  4. Feb 1, 2013 at 2:46 PM
    BudTRD
    Brian
    California
    so i can run some kind of a check to see what thye codes were even though the light is no longer on?
  5. Feb 1, 2013 at 2:47 PM
    BudTRD
    Brian
    California
    where is the brake switch located?
