Engine Rattle in V6
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ILikeTacos, Oct 1, 2010.
  1. Oct 1, 2010 at 12:18 PM
    ILikeTacos
    ILikeTacos [OP] Member
    Az
    08 Sport Long Bed
    Clean
    Looking for some help with a noise I have in my engine. I have an 08' Tacoma Prerunner (V6, 2WD, Tow Package, AT) that has a rattle coming from the engine at around 1500 - 2200 RPM.:( It usually happens when I accelerate moderately from lower speeds. It isn't very loud and I do have to turn the stereo off to hear it. It reminds me of what the older diesel engines sounded like with that rattle/knocking sound. I took it in to the dealer and was told that it is a normal engine noise from this V6 and not to worry about it. Well it doesn't sound normal to me. I'm thinking possible rod knock even though it isn't that loud. Has anyone else heard this noise? Anyone know of issues with these engines? Please let me know. Thank you.
  2. Oct 1, 2010 at 12:23 PM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    are you sure it dont sound more like a ticking noise? A rattle could be loose skid plate or something that when it hits a certain rpm. The ticking is normal.
  3. Oct 1, 2010 at 2:39 PM
    nhstang
    nhstang Well-Known Member
    Brian
    Nashua, NH
    2010 TRD Sport Double Cab
    Stainless Step Bars, Extang Trifecta Tonneau
    The timing chain is very noisy in these engines. That's the closest to a "rattle" probably. It's just a noisy engine and there's very little sound damping between you and it.
  4. Oct 1, 2010 at 2:39 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    could it be the problem with the stock air box and the attachment that goes into the fender well being loose?
  5. Oct 2, 2010 at 10:53 AM
    ILikeTacos
    Az
    08 Sport Long Bed
    Clean
    Thanks for the replies. I haven't heard anything about the airbox, so I could look into that. The timing chain thing sounds like it could be the problem. I had a 95' pickup with the 22R that made a similar noise and it was the timing chain. The rattle or clack or whatever you want to call it does go up and down with engine rpm. I hope that these engines are not like the old ones where the timing chain would eat through the timing cover case and into the coolant passages. That was a nightmare. I'm going to run out of warranty soon, so I just wanted to find out if this was a common thing.
  6. Oct 2, 2010 at 11:01 AM
    JasonJump
    JasonJump Well-Known Member
    Yukon Oklahoma
    '05 Tacoma TRD Sport 4X4 D Cab Debadged
    Billy 5100's set at 2.5, iPhone innerface, TRD Sport wheels powdercoated Anthracite grey wrapped in 265/70/17 Duratracs, Custom Sliders
    I have the exact same issue on my '05 I know exactly what u are talking about, I really hear it when in reverse at 1,200 to 1,500 rpm's almost sounds like a hose leak.... like air/rattle in the front passenger side of the engine which leads me to believe its in the air intake hose somewhere... its soooo annoying. And I don't know if its normal but the hose into the side fender wall seems kind of lose... but no real way to tighten it. anyways, I saw there might be a TSB on it, but I am way out of mileage warranty... but hope this helps pin point your issue :rolleyes:
  7. Oct 2, 2010 at 11:19 AM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    I also have it but the noise is "engine load" dependant (you have to be at low rpm/high load) which would exclude the timing chain. My guess is exhaust manifold design that is causing the noise.
    Search for "tick" or engine noise in the forums to see a lot of related posts
  8. Oct 2, 2010 at 11:33 AM
    JasonJump
    Yukon Oklahoma
    I agree with the "load" its when I am back up like up a hill... has to struggle a little more than normal in order to make the noise, but its def not the tick everyone talks about. Sounds like plastic is almost lose rattling/air being restricted
  9. Oct 2, 2010 at 11:46 AM
    west467
    west467 Well-Known Member
    Two Black Tacos..03 and 09
    My 2009 V6 had something similar, it sounds like pinging under load. (detonation)
    I now use premium fuel and it runs great. I have heard some V6's run with 87 others don't. Try some 93 octane fuel...see if that helps.
    Good luck
  10. Oct 2, 2010 at 11:48 AM
    JasonJump
    Yukon Oklahoma
    Nope not pinging... I run 91 its the highest available where I live, its def coming from the air intake somehow... its an air plastic rattle
  11. Oct 2, 2010 at 1:37 PM
    supralight
    Dan
    Earth
    I'm using 91 and my engine still ticks so that is not a fix
  12. Oct 3, 2010 at 5:09 PM
    JasonJump
    Yukon Oklahoma
    I was able to pin point my rattle/noise today, its coming from my air intake hose... seems to be rattling against something, I had my wife press the gas and brake while in reverse and I could move it and make the noise... further investigation is on the way ha
  13. Oct 3, 2010 at 6:04 PM
    WABOOM
    WABOOM Well-Known Member
    Minnesota yeah sure ya betcha
    2013 F-150 XLT Supercrew 4x4
    debadged
    Air intake tube TSB
  14. Oct 3, 2010 at 6:35 PM
    west467
    There is no fix for the "Toyota tic"...
    The OP described my problem almost exactly. 93 octane fixed my issue.
  15. Oct 4, 2010 at 7:02 AM
    JasonJump
    Yukon Oklahoma
    Since I am out of warranty to you know what the exact problem is? Or do I need a new Tube> Thanks man
  16. Oct 5, 2010 at 3:53 PM
    WABOOM
    debadged
    $90 Tube assembly from dealer. or just stuff foam around it. that's what I did. It's right where the intake goes thru the inner fender.
  17. Oct 6, 2010 at 7:39 AM
    JasonJump
    Yukon Oklahoma
    Thanks, I actually put a Downhill bike tube rapped around the hose into the fender wall, now it can't move and its just rubber against metal and the tube is bomb proof. No more Rattle!!! If anyone is have this issues a tube also works great. I did this since my truck is out of warranty and could not perform the TSB intake hose rattle on it.
  18. Oct 8, 2010 at 7:22 AM
    tcrast1
    tcrast1 Active Member
    Tom
    Chicago, IL
    05 SR5 4x4 DC LB 3P1
    I am going to try this when I get out of work today. This rattle noise is really annoying, and what you described is exactly what mine sounds like except it sounds like it's coming from the center. I had my mechanic take a look and he thought it was the tensioner pulley, which will be insanely expensive to change...
  19. Oct 8, 2010 at 7:25 AM
    desertdude59
    desertdude59 CRAZY 4WHEELER
    From the Mojave desert now in Wild and Wonderful W
    1991 toyota 4x4 sr5-lost but not forgotten
    4" lift after market front bumper bed mount lightbar/roll bar (4)6" kc's on the roll bar (2) kc flat back bumper mounts f/r gears for the 33's
    The v6's dont have chains :)
  20. Oct 8, 2010 at 7:33 AM
    MAtrdguy
    MAtrdguy Well-Known Member
    Pete
    Western Ma ( on the lake) / Danvers N Shore
    06 Taco DC LB
    None YET
    my rattle is at idle...I mentioned it to Toyota and they said it was the injectors clicking....I rolled my eyes cause I know the sound of a mettalic rattle..then he said timing chain cover
    does the V-6 have a chain or belt ??
    I think the tech @ Toyota should consider a career change..I cant hear ( 1/2 deaf ) and could hear it !!
    going back next week
    I'm SO dissapionted in this truck...so many issues !!! i dont have the time to keep going back)
