Engine Rattle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Garcoma, Apr 1, 2022.
  1. Apr 1, 2022 at 12:07 PM
    Garcoma
    Garcoma [OP] Active Member
    Garrett
    2012 Silver Tacoma TRD Offraod Access Carb
    Hoping someone has heard this before and can save me some time. It almost sounds like a loud rattle snake. It occurs when letting off accelerator or light acceleration, also around turns under light acceleration/deceleration. Seems to me like it's coming from the belt. I thought it was the tensioner at first so I replaced the bearing only and a new belt. Also, hit the tensioner with air and WD because some have mentioned this helps rid the dust and debris. None of it has helped and it's progressing. It's a 4.0 automatic 2wd with 142k miles.
    Here's a video, excuse all the external mic noise:
    https://youtu.be/rP-WDlDh1HY
  2. Apr 1, 2022 at 7:01 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    2015 Toyota Sienna with rear locker
    Audio is not good enough for us to really know anything but might be your power steering pump. Check the power steering reservoir and consider doing a fluid swap (pretty easy job all things considered). Check the condition of your belt too.
  3. Apr 1, 2022 at 7:09 PM
    Gtlegacy
    Gtlegacy Active Member
    You can rule out the other idler pulleys by starting it for a short duration with the belt off.
    Key-Rei likes this.
  4. Apr 2, 2022 at 9:33 PM
    Waasheem
    Waasheem
    2007 xrunner
    For some reason, this gave me flash backs. Driving a 70 nova with messed up motor mounts. If you gunned it too much from a stop, the engine would jump out of place, the fan would scrape the shroud, and the throttle cable would get yanked causing it to be floored. Made for a few interesting experiences.
    I agree with wi taco, check power steering. Might just be low fluid. Power steering noise could be described as a loud rattle snake.
    Try another video, not driving, engine running, turn the steering wheel until it stops, then back the other way until it stops.
  5. Apr 3, 2022 at 8:43 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Check for a loose skid plate. Also, the u-joints, and support bearing, even if it sounds like the noise is coming from the engine bay. (I cant hear the audio on my cell.)
