Engine rebuild or replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SedonaTRD, Oct 25, 2024.
  1. Oct 25, 2024 at 4:12 PM
    SedonaTRD
    SedonaTRD [OP] Member
    2012 Tacoma TRD 4x4
    None
    Anyone ever had to rebuild or replace the 4L, V6 engine? Appreciate any info on cost to do so; which is better - rebuild or replace? Any place in Arizona that does such work? Thanks!
  2. Oct 25, 2024 at 4:18 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It all depends on who is rebuilding it. And why it needs rebuilt.
    But mostly, it's who rebuilds it.
    The good builders are NOT cheap.
    The 1GR is a sleeved block. You can't just bore, hone, and slap pistons in it.
    You actually HAVE TO measure stuff.
    Dm93 likes this.
  3. Oct 26, 2024 at 7:46 AM
    TacoTuesday1
    FL
    No I have not. Why.
    DIY can be more attentive and cheaper.
  4. Jul 8, 2025 at 3:28 PM
    SedonaTRD
    2012 Tacoma TRD 4x4
    None
    Thanks for the responses...
