Engine rebuild
Discussion in '1st Gen. Tacomas (1995-2004)' started by bjb1411, Dec 11, 2019.
  1. Dec 11, 2019 at 12:26 PM
    bjb1411
    bjb1411 [OP] New Member
    Beaux
    01 tacoma 4wd 3.4 5vzfe
    So i have an 01 3.4 5vzfe, did all the normal tests and everything and have come to the conclusion the rings are bad on cylinder 3 for sure, possibly 1 and 5 also. So with that being said, does anyone have a rebuild kit that they’d suggest? Thanks
  2. Dec 12, 2019 at 8:23 AM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    come on TW, help this guy out.
  3. Dec 12, 2019 at 8:45 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    being a Tacomaworld member for a while in my vast exploration (while at work) of the site the consensus points to a low mileage replacement or JDM replacement vs. rebuilding the engine. There are options for a rebuild and some reputable builders. However - it will cost the price o a used 200K mile Tacoma 4x4 to get done. The engine however can be 1/2 that price almost. If you can do the work yourself you save yourself a lot of money. More time but less money this way.
  4. Dec 12, 2019 at 8:50 AM
    96carboard
    96carboard Well-Known Member
    Care to share the testing results for others to confirm your analysis? Would hate to see you rip the engine that far down if it just needs some valve work.
    koditten likes this.
  5. Dec 13, 2019 at 5:05 AM
    bjb1411
    Beaux
    So i have a very close friend of mine that has rebuilt a ton of engines and i have also myself just not on a toyota. that’s why i’d rather do a rebuild on it, to have that under my belt for the most part lol. This isn’t my primary vehicle but it will be my commute vehicle which is 156 miles a day. I’ve drove around 23k miles in the last 4 months so i’d like to have it pretty well new, just looking for a good rebuild kit.
  6. Dec 13, 2019 at 5:14 AM
    bjb1411
    Beaux
    Cylinder 1: 90psi
    Cylinder 3: 0psi wet 110psi which dropped pretty quickly in my opinion
    Cylinder 5: 100psi
    so i also brought cylinder 3 up to tdc, put some air to it and it was blowing to crankcase pretty bad. With that being said, the guy i bought it from had apprently ran it extremely hard with lack of maintenance or inspection lol. In the air tube in the fender to the air box was 1/2 full of mud. Also, there was no filter in the airbox and the tube was broke to the air box. Pretty sure it was like that for a while so i’m positive it sucked up a bunch of trash and scarred up the cylinder walls pretty extreme. Hopefully just be able to change mostly everything on the bottom end and hone it but we’ll see when i tear it apart
  7. Dec 13, 2019 at 5:21 AM
    96carboard
    Since you have positively identified serious leakage into the crankcase, that does suggest that you're on the right track.
    If there is suspicion of having ingested mud, dirt, sand, and potentially even water, I would definitely lean toward replacing the engine rather than rebuilding it. IMO, honing it probably wouldn't be sufficient. This block sounds like a candidate for being bored.
  8. Dec 13, 2019 at 6:13 AM
    bjb1411
    Beaux
    That’s going to be the determining factor of what i’m going to do probably. Once we have it torn apart i’ll be able to see if it needs boring or could get by with honing. But i do believe with as bad as it is, it’ll probably need boring so if that’s the case i may try to just get a used or JDM. Trying to keep it cost efficient as possible due to the fact that their is still other work that needs to be done. I only paid $800 for the truck but i’m also not trying to have to spend 8k on it lol.
  9. Dec 13, 2019 at 6:20 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I'm subbed for curiosity sake.
    bjb1411[OP] likes this.
