Engine Rebuild
Discussion in '1st Gen. Tacomas (1995-2004)' started by Justin723, Dec 22, 2009.
  1. Dec 22, 2009 at 3:42 PM
    Justin723
    Justin723 [OP] Dont judge me
    Justin
    Phoenix AZ
    01 Tacoma SR5
    Performance- bored .20 over, Doug Thorely Headers, Magnaflow Exhaust, and K&N cold air intake. Exterior- 7 inch lift, ARB compressor, high pinion 4.88 with ARB locker, 4.88 open diff in the rear, PIAA 520 series lights up front, and 36 inch fire stick. Interior- 2 10inch JL W1 subs, Alpine MRX-V70 amp, Alpine type R SPR 17C 6x6 speaker in the back, Focal 165 VR with crossover tweeter up front, Cobra LTD CB, and Weather Tech floor mats.
  2. Dec 22, 2009 at 5:18 PM
    Justin723
    Justin
    Phoenix AZ
    01 Tacoma SR5
    Anyone.
  3. Dec 22, 2009 at 5:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Being an Cast Iron block, I dont think you would need to sleeve it.
  4. Dec 22, 2009 at 5:45 PM
    Justin723
    Justin
    Phoenix AZ
    01 Tacoma SR5
    Well what do you think the best option is to do a stock rebuild?
  5. Dec 22, 2009 at 5:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Depends on the condition. You should be able to bore it 020 over with no issues.
  6. Dec 22, 2009 at 5:51 PM
    Justin723
    Justin
    Phoenix AZ
    01 Tacoma SR5
    Its got 168k miles on it and its starting to get an abnormal tick, not valve train or the normal toyota tick, it sounds like pistion slap to me so i figured might as well just rebuild it before it gets worse.
  7. Dec 22, 2009 at 6:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Do it.
  8. Dec 22, 2009 at 6:05 PM
    Justin723
    Justin
    Phoenix AZ
    01 Tacoma SR5
    That kit i posted, you think thats got everything i need?
  9. Dec 22, 2009 at 6:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Looks like it.
  10. Dec 22, 2009 at 6:35 PM
    Justin723
    Justin
    Phoenix AZ
    01 Tacoma SR5
    Alright. What about quality im kinda scared that its so cheap it might be shitty.
  11. Dec 22, 2009 at 7:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I have no idea what their quality is like.
  12. Dec 22, 2009 at 7:17 PM
    Justin723
    Justin
    Phoenix AZ
    01 Tacoma SR5
    Well do you have any suggestions on where i could go to buy the rebuild kit?
  13. Dec 22, 2009 at 7:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Not off hand. Sorry..
  14. Dec 22, 2009 at 7:26 PM
    Justin723
    Justin
    Phoenix AZ
    01 Tacoma SR5
    As far as the gaskets im not to worried about but the pistons and bearings think i should go with some aftermarket brands or just stock?
  15. Dec 22, 2009 at 7:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Search out google, and see if there are some good aftermarket ones out there. If your gonna be elbow deep in the engine, you may as well get the best.
  16. Dec 22, 2009 at 7:44 PM
    Justin723
    Justin
    Phoenix AZ
    01 Tacoma SR5
    Thats what i was thinking. Ive been searching for a while and all ive noticed is the same stuff just different price range.
  17. Jan 5, 2010 at 10:51 PM
    matthew5olson
    matthew5olson Well-Known Member
    matthew
    pittsburgh, PA
    04 ext cab 3.4L 5spd 4x4 sr5
    K&N cold air intake, doug thorley headers, rear sensor simulator, flowmaster 40 series, magnecor plug wires, Royal Purple synthetic gear lube, airaid throttle body spacer, Hyperground system, flex-a-lite elec fan.
    http://www.lcengineering.com/ good quality high price. They say 4 cyl but I know they have parts for the 5vz-fe
    engnbldr is also very good. Don't know if the do the 3.4 though. Those will be your best quality. the engnbldr guy is a great honest guy. Have heard nothing but good things about him.
  18. Jan 24, 2010 at 10:28 PM
    trucklover63
    trucklover63 Active Member
    illinois
    04 PreRunner sr5
    how is the rebuild job going,justin?
  19. Sep 23, 2014 at 6:53 PM
    jmlinne
    jmlinne Well-Known Member
    Mitch
    Montana
    '97 Tacoma 4x4 w/ 5-speed manual and locking hubs, stock for now
    I bought aftermarket rings and gaskets on-line for my 2.7L overhaul. I checked the ring gap and it was at least 5 thou. too small. Of course the company is shipping me another set but I'm thinking Toyota would have been a better choice.
