Engine Removal Tips? Help, it’s stuck!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Brandon###, Jun 27, 2022.
  1. Jun 27, 2022 at 8:22 AM
    Brandon###
    Brandon### [OP] Well-Known Member
    I’m in the process of removing the engine (4.0) and I can’t seem to lift it out of the engine bay.
    It’s completely free of the transmission. I can lift it up a bit, but can’t seem to move it forward more than an inch or so. The flex plate is just barely clear of the bell housing.
    Do the exhaust manifolds to to be removed? Do I need to do anything with the transmission?
    Any tips or advice would be greatly appreciated!
    (A helping hand in the Austin area would leave with multiple cases of beer)
  2. Jun 27, 2022 at 8:27 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    All wire harness connections free? A/C line at the bottom front of engine free from the engine?
    Engine mounts completely free?
    Exhaust sensors unplugged from harness?
  3. Jun 27, 2022 at 8:28 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I think I pulled the intake and exhaust manifolds on the last one I did before removing it and it was easy, do you have the radiator and fan off ?
    b_r_o likes this.
  4. Jun 27, 2022 at 8:28 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Torque converter bolts removed from flex plate?
    maineah and b_r_o like this.
  5. Jun 27, 2022 at 8:36 AM
    Brandon###
    Both nuts are removed from the mounts. I can lift it a few inches above the studs.
    O2 sensors are unplugged.
    Intake is off. Radiator and fan are out. I’m trying to lift it a bit, and then pull it forward into that empty space so I can lift it out.
    Yes, all bolts are out. I have it out just enough to clear the alignment pins on the bell housing.
  6. Jun 27, 2022 at 9:06 AM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    Kind of hard without seeing it first hand. If it's hanging up, it's gotta be hanging up on something. Maybe get underneath with a flashlight and really get a good look.
  7. Jun 27, 2022 at 9:08 AM
    Brandon###
    Totally understand. I was just wondering if I was overlooking something.
    I still have the exhaust manifolds attached, but wasn’t sure if that’s causing the hang up. It’s hard to tell when you’re lifting it solo, what’s hanging up as it goes up.
  8. Jun 27, 2022 at 9:13 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Driver side exhaust manifold might, on the steering column.
    Heat hoses as the back of the engine also can.
    Brandon###[OP] likes this.
  9. Jun 27, 2022 at 9:14 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You pulled the a/c compressor off and unplugged the crank position sensor as well?
  10. Jun 27, 2022 at 9:15 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Even with the flex plate bolts removed the torque converter can still be "stuck" to the flex plate, sometimes have to pry them apart carefully.
  11. Jun 27, 2022 at 9:23 AM
    Brandon###
    AC compressor and power steering pump are off.
    Good call on the crank position sensor, I’ll need to check that. Is it near the crank pulley?
  12. Jun 27, 2022 at 9:24 AM
    Brandon###
    i noticed the driver side manifold was pretty close to the firewall and steering shaft. I may just go ahead and pull it off.
    I’ll double check those hoses. I removed them from the firewall since it was easier to get to.
  13. Jun 27, 2022 at 9:25 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    This, the converter must be able to turn free you run a risk of damaging the trans pump if it isn't.
  14. Jun 27, 2022 at 9:34 AM
    Brandon###
    Thanks, I can see daylight and almost put my hand between the torque converter and flex plate.
  15. Jun 27, 2022 at 9:47 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It is near the crank pulley, and easily accessible with the a/c compressor removed.
  16. Jun 27, 2022 at 3:44 PM
    Brandon###
    Confirmed that the crank sensor is still plugged in (whoops, it’s hidden pretty good in there).
    I’ll report back on Saturday, hopefully with a pic of an empty engine bay.
    stickyTaco and Torspd[QUOTED] like this.
  17. Jun 27, 2022 at 4:47 PM
    Fullboogie
    Dave
    Houston
    Keep up the good fight, Brandon. It's a learning experience.
    Brandon###[OP] and dbittle like this.
  18. Jul 2, 2022 at 6:36 AM
    Brandon###
    I found 3 reasons it wasn’t budging
    1. Crank sensor was still connected
    2. O2 sensor on the rear was unplugged, but the plug needed to be disconnected from the bracket
    3. The main reason: The passenger side exhaust manifold bracket was still bolted to the bell housing. I could have sworn I removed it.
    TLDR- When it’s 120 degrees outside and things don’t seem to be going as they should. Walk away for a couple days and get some helpful hints from friendly folks on the internet.
  19. Jul 2, 2022 at 6:52 AM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    Nice. Lol sometimes it’s the most simple things that we miss
  20. Jul 2, 2022 at 7:25 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Lots of good parts on there.
