Engine Replacement advice needed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 10316133, Mar 20, 2017.
  1. Mar 20, 2017 at 8:13 AM
    10316133 [OP] Member
    2014 Tacoma Off Road, 2007 Tacoma
    Hi all...
    I need to replace the engine in my 2007 Access Cab 4x4. I recently found a low mileage engine getting parted out from a 2014 4x4 for sale in my area. So...
    I'm assuming (probably wrongly) that I can swap engines straight across. I'd like to hear from anyone who has either done this, or is knowledgeable in this area about what I should be prepared for, or if you can offer any tips!
    Thanks in advance, I appreciate any info!
    JD
  2. Mar 20, 2017 at 9:57 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Bolt over swap. Very easy. For me at least. ;)
  3. Mar 20, 2017 at 3:28 PM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    There will be some differences. I would guess that the engine would bolt up, but your 07 doesn't have the air pump. Having owned an 06, 13, and a 14, expect your mileage to drop a mile or two and some newer engines have different noises than your 07 such as startup piston slap. I would guess that there's nothing that you couldn't overcome taking parts from one to the other. Whether there's any difference in computer because of the air pump I couldn't say.
  4. Mar 22, 2017 at 11:07 AM
    baboon
    baboon Active Member
    There will be computer differences with respect to the air pump.
    But the good news is that this is solved by not installing the air pump. Just block it off.
    Bonus: Your air pump will never fail.
  5. Mar 22, 2017 at 11:46 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Swap headers and no need to worry about the air pump.
  6. Mar 23, 2017 at 9:22 AM
    Thanks to everyone who responded. I was mostly worried about computer differences but it sounds like it's not a big deal. I'm gonna lift the cab off to swap out the engine and tranny - I'll post pictures soon!
  7. Mar 23, 2017 at 9:34 AM
    Pabloeeto
    Pabloeeto Well-Known Member
    Paul
    San Diego
    06 DCSB TRD Sport 4x4
    K&N filter, 3.5 Aux input mod, Fox 2.0 Coilovers, Fox 2.0 Resi Shocks, Element UCAs, Old Man Emu Dakar Leaf pack.
    whats the back story from your original engine, just curious how it went or whats wrong with it.
  8. Mar 23, 2017 at 9:44 AM
    doorsidedown
    doorsidedown Well-Known Member
    Hell yes. Subd for pics!
  9. Mar 23, 2017 at 9:51 AM
    That'a a very good question. The original engine is still in the vehicle so I haven't done a full autopsy yet. The engine has 350,000km on it. Driving along the highway in December, the engine just stopped. I glided to the side of the road and switched off the key. The engine of course wouldn't turn over. There was oil in the crankcase, and the temp warning light never came on. I towed it to the dealership and they pulled off the oil pan. They couldn't say for sure what had happened without spending a lot of $$ so I towed it home and parked it in the garage. As soon as I get it out (hopefully this weekend) I'll get a better idea. I'm hoping I didn't do any permanent damage to the cylinder block or the heads. My gut feeling is I piled up a bottom end bearing.
    I should also mention that this is my hunting rig, so it puts on lot's of miles in pretty crappy conditions, including cold starts in -40 weather etc. I was pissed when it quit, but it doesn't owe me a cent LOL
    Pabloeeto[QUOTED] and Torspd like this.
  10. Mar 23, 2017 at 9:54 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Which weight oil did you normally run in that engine?
  11. Mar 24, 2017 at 10:03 PM
    I ran 5-30 as per spec. I used conventional oil not synthetic. I'd do an oil and filter change about every 7 to 8000 km... Okay maybe 10,000
  12. Mar 24, 2017 at 10:23 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    To many miles for conventional.
  13. Mar 24, 2017 at 11:09 PM
    You are very likely correct sir!
