Engine replacement needed?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SLeeper512, Mar 16, 2021.
  1. Mar 16, 2021 at 6:21 PM
    SLeeper512
    SLeeper512 [OP] Well-Known Member
    Sam
    2021 SR5 DCLB Tacoma white with red topper with tow pkg
    Thoughts on engine replacement, or other actions.
    So a week ago I'm cruising down the interstate in 4th at about 60 towing a 3500# trailer when all of a sudden I lose power (the engine was still running) and the CEL and Trac light both come on.
    Their was a slight noise when it initially happened. It would start, but I had to keep the rpms up to prevent from stalling and it otherwise seemed smooth and quiet.
    Anyway the mechanic says the code was calling for a crankshaft position sensor...
    Then when that didn't work he discussed with the local Toyota dealer and they determined that it needed a new computer. (It's a long story, but I happened to have a spare... that was what was originally in truck). That didn't work...
    Now he saying that the code is suggesting that number 2 cylinder has a valve issue.... (I've never had a quiet bad valve).
    I had him stop work... am looking to take to another mechanic, who often does engine replacements &/or rebuilds.
    The 2015 4WD SR5 has about 170k miles... oil changes every 5k, tranny fluid changed, diff changed 30-40k... was also regeared and I run 32" tires... so would usually run around 3000 rpm in 4th while towing and I do a lot of towing...
    Thanks
  2. Mar 16, 2021 at 6:24 PM
    Clearwater Bill
    Billy
    Largo Florida
    As you've figured out, you need a new mechanic.
    An honest one who can also diagnose.
    Dm93 and HisDad like this.
  3. Mar 16, 2021 at 6:29 PM
    SLeeper512
    Sam
    Well I guess one question would be has anyone ever had a valve go bad, broke spring, etc that was quiet. I've seen a valve sucked into an engine and it made a lot of noise and other damage. Also had an exhaust valve burn out and you definitely knew you were running on one less cylinder.
  4. Mar 16, 2021 at 6:32 PM
    Clearwater Bill
    Billy
    Largo Florida
    Burnt valves, yes, noise free. Broken stuff, no.
    But a compression test, dry / wet followed by a leakdown test will ferret out those flaws. Basic stuff.
  5. Sep 5, 2021 at 5:06 PM
    Fireweed
    Fireweed New Member
    1998 Tacoma Extended Cab 4WD
    shell on bed
    I have 98 Tacoma 4 cylinder. It has started to need to be shifted into 3rd gear and even sometimes 2nd on highway hills to keep up with traffic. It never did this before. When is the tipping point to get a repair or a new engine? 260000 miles on it and all maintenance done on time.
  6. Sep 5, 2021 at 5:29 PM
    Waasheem
    Waasheem
    2007 xrunner
    This!
  7. Sep 5, 2021 at 5:37 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Only you can decide that. To some people sinking $3k into a $2k vehicle is worth it. Others stare at that $2k value as if it is going out of style.
    The better question is, what is it worth to you?
  8. Sep 5, 2021 at 7:14 PM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    You don't have nearly enough information to make a decision. Find a new shop.
  9. Sep 6, 2021 at 3:20 AM
    TacoTuesday1
    SD CA
    that's not a mechanic
    SLeeper512[QUOTED][OP] and Dm93 like this.
  10. Sep 6, 2021 at 1:42 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    This was in March, has the problem been identified and resolved? Going just by the first sentences, I'm thinking electrical (bad coil) or a vacuum leak from a ruptured vacuum hose or even a bad PCV valve. What was/were the actual code(s)?
  11. Sep 6, 2021 at 5:51 PM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    You may have better luck posting athread in the 1st gen forum. Like the OP on this thread, find a trusted mechanic that can perform various tests and check for codes before hastily blame it on a failed engine or transmission.
