Engine Replacement With JDM Engine.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Herm4376, Oct 18, 2015.
  1. Oct 18, 2015 at 5:22 PM
    Herm4376
    Herm4376 [OP] Member
    I'm replacing my 3.4L 5VZ-FE engine in my 2002 Tacoma which blew a connecting rod and considering going with a JDM. I'm looking for some definitive answers of what can be utilized from the JDM and what must be swapped from the original engine. I have already removed the original engine leaving the entire wiring harness inside the engine bay for reuse with the new engine. I believe I have a fairly definitive list of what can be used from the JDM and what must be swapped from the original engine, but would like feedback from anyone who has done a JDM replacement.
    According to my research so far the following need to be swapped from the original engine to the JDM replacement:
    • Intake
    • Fuel injectors
    • Exhaust manifold
    • Motor mounts
    • Oil pan
    Parts which I don't have a definitive answer regarding whether or not they can be used from the JDM :
    • Alternator
    • P/S Pump
    • A/C Compressor
    • Oil sump/pickup tube
    • Pulleys
    Item that require modification:
    • Move oil filter to front of block and install oil cooler to back location (original oil filter location on JDM)
    Have I missed anything?
    Also is swapping the oil pan do you also have to swap the Oil sump/pick up tube?
    For those who have gone with a JDM did that have any problems other than swapping the parts above? Anyone have any long term success with JDM engines?
    Appreciate the feedback.
  2. Jan 1, 2016 at 3:52 PM
    MindFork
    MindFork Active Member
    PNW
    99 Xcab V6 4x4 TRD
    Did you go with the JDM engine? Why can't the injectors on the JDM engine be used?
    opteron likes this.
