Engine replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CJ303, Aug 23, 2023.
  1. Aug 23, 2023 at 2:19 PM
    CJ303
    CJ303 [OP] Member
    2006 Silver Tacoma 4x4 Access Cab
    Old 4 cylinder engine has 260k on it and it blew its head gaskets. If I replace the engine would I be able to fit the 6 cylinder in it is the spacing differ from the factory. Would the 6 cylinder work with my 5 speed manual transmission or would I have to replace that too?
  2. Aug 23, 2023 at 2:29 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Ugh. Dude, you will need the entire ECU to go with that engine. Not like my days where we could swap in a day or two, with no electronics lol
    CJ303[OP] likes this.
  3. Aug 23, 2023 at 3:14 PM
    CJ303
    CJ303 [OP] Member
    That’s what I was afraid of… in your opinion is it worth replacing or worth trying to just replace the gaskets?
  4. Aug 23, 2023 at 3:19 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    The tranny wouldn’t bolt up either I don’t think. The V6 has a 6 speed.
    Head gasket might not be too bad on a 4 banger. Only one head.
    Geeves77 likes this.
  5. Aug 23, 2023 at 3:20 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It’s different. It won’t fit.
    Engine and trans mounts don’t line up.
  6. Aug 23, 2023 at 3:20 PM
    eon_blue
    Azusa, CA
    unless you overheated it and warped/cracked the heads, I don't think a head gasket job on a 4 banger would be that bad to do. Certainly less work than swapping a different kind of engine into it
  7. Aug 23, 2023 at 3:23 PM
    Geeves77
    Mark
    Northeast
    2011 Tacoma DCSB
    Change head gasket
  8. Aug 23, 2023 at 3:27 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Condition of truck?
    Body mounts cab corners, frame etc?
    Replace head gasket, maybe rebuild engine? And drive on!
  9. Aug 23, 2023 at 3:31 PM
    Hunter gatherer
    Hunter gatherer Well-Known Member
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    I would do a head gasket,doesn't get any easier than a 4 banger.
  10. Aug 23, 2023 at 3:31 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Change headgasket or install junkyard motor
