engine rev when tapping brake going downhill
Discussion in 'Technical Chat' started by dusty64, Sep 27, 2012.
  1. Sep 27, 2012 at 3:39 PM
    dusty64
    dusty64 [OP] New Member
    hello there
    new member and I apologize already if there is an answer to this, but couldn't find any in my searches.
    I have a 2012 double cab toyota tacoma, v6. When I'm going downhill, if I tap on the brakes at about 40 - 45mph the engine revs up to around 2000rpm - it's pretty much like it's downshifting. If I tap on the gas it revs even higher before it settles back down.
    Not a total "truck-gal" yet but I'm learning so be kind ;) but wanting to make sure I don't have an engine problem.
    Thanks for any responses
  2. Sep 27, 2012 at 3:46 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    That should be the downhill assist so you arent wearing out your breaks trying to slow the truck down so the engine downshifts to compensate.
  3. Sep 27, 2012 at 3:57 PM
    Ryan DCFS
    Ryan DCFS Elevator guy
    East Bay Area
    09 DC long bed TRD silver streak
    This.
    No engine problems to worry about... Don't feel bad though, I thought it was strange when I first got the truck and didn't know the computer was doing it on purpose.
  4. Sep 27, 2012 at 5:29 PM
    Casey05Taco
    Casey05Taco Well-Known Member
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    trd seat covers, bed mat, tinted windows, debadged, mud flaps removed, tinted tails, blacked out center console, Black Rims, 6000k HID in highs and fogs, blacked out front emblem, Pioneer AVH-4300DVD, Gauge Cluster, lower valence, retrofitted, audio system, Maxtrac Spindles, Billies
    Just wanted to point that that we actually had a new member use the search function.
  5. Sep 27, 2012 at 5:31 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Engine braking
  6. Sep 27, 2012 at 5:33 PM
    Rascal737
    Rascal737 Well-Known Member
    Oliver
    Abbotsford, BC
    09 Silver DCLB TRD Sport 4X4
    Python 574 Remote start/Security system, reusable cabin air filter, led map and dome lights, led bed lights, switchback dtrl's, aftermarket dual halo projector headlights retrofitted with TRS goodies, foglights on anytime, Illuminated 4X4 switch, Redline hood struts and EZ down tailgate, Weathertech front and rear floor liners, Black Westin 4" oval step bars
    what year did they put the downhill assist as standard equiptment??
  7. Sep 27, 2012 at 5:36 PM
    Rascal737
    Oliver
    Abbotsford, BC
    you put "truck-gal" but your gender show's male??? sorry, off topic i know but just curious
    Oh and welcome to TW from BC Canada!!
  8. Sep 27, 2012 at 5:40 PM
    jtgroce
    jtgroce Got R Did
    In the Foothills, NC
    '12 Taco MGM TRD Off Road
    K&N Air Filter Husky Floor Liners Weathertech Vent Visors LED Map/Dome Light Mod Chrome Door Handles AVS Bugshield Bed Mat Fog Light Anytime Mod DTRL LED's Flowmaster Super 40
    in 1969 :rolleyes:............ I think the '05 I had did it
  9. Sep 27, 2012 at 5:42 PM
    Rascal737
    Oliver
    Abbotsford, BC
    is there anyway to disable it?? is there a switch like on the tundra's??
  10. Sep 27, 2012 at 5:44 PM
    jtgroce
    jtgroce Got R Did
    I don't know about that, never heard of anyone disabling it
  11. Sep 27, 2012 at 5:50 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Neg. DAC is a 4x4-only feature for off-road. You press the DAC button on the dash and the truck crawls down steep grades at a more or less constant speed.
    What the OP is seeing is the transmission downshifting to slow the truck down, and is simply part of the ECM shift logic. For trucks, downshifting and using engine braking to control your speed when going downhill is the safe method, because you can't burn up your brakes, lock up your wheels or swing the tail out. No difference in fuel economy because your foot is off the gas. The Chevy 2500 and 3500 trucks with the Allison tranny had the blip-brakes-to-downshift feature as early as the mid-1990s.
    With bigger trucks carrying heavier loads it becomes increasingly more critical to use engine braking. A fully-loaded 18-wheeler going down a steep hill will crash if not in the right gear at the top of the descent.
  12. Sep 27, 2012 at 5:53 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    I heard if you remove the CPU, which is located on the passenger's kick panel, it will let your truck roll without any engine braking.
  13. Sep 27, 2012 at 6:20 PM
    Rascal737
    Oliver
    Abbotsford, BC
    OK, that's what I thought because I don't have a DAC button on my dash...but I get the transmission shifting on down hills quite often, which bugs me so I'll usually shift into 4th and back to drive and it goes back to normal
  14. Sep 27, 2012 at 6:26 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    If the auto programming is anything like the stick's then it has to push rpm over 1600 to activate the fuel cutoff.
  15. Sep 27, 2012 at 6:27 PM
    OZ-T
    Peter North
    British Columbia
    Just hit the gas
  16. Sep 27, 2012 at 6:36 PM
    Rascal737
    Oliver
    Abbotsford, BC
    Tried that...just rev's really high.
  17. Sep 27, 2012 at 6:37 PM
    KenLyns
    Belly of the Beast
    EDIT: How high is "high" for you? I see typically about 3000 rpm when engine braking.
  18. Sep 27, 2012 at 6:37 PM
    OZ-T
    Peter North
    British Columbia
    Then it's not engine braking
  19. Sep 27, 2012 at 6:43 PM
    Rascal737
    Oliver
    Abbotsford, BC
    The truck will down shift into 4th when I apply the brakes but it'll rarely shift back to drive, unless I hit a flat portion of the road and engine load goes back down...if that makes any sense
  20. Sep 27, 2012 at 6:46 PM
    Rascal737
    Oliver
    Abbotsford, BC
    Whipper....you are a comedian my friend!!! can always depend on you for some helpfull advice!! :D
