Engine Reving no power
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Madchild, Apr 10, 2009.
  1. Apr 10, 2009 at 5:07 AM
    Madchild
    Madchild [OP] Well-Known Member
    Bloomington MN
    Slim's HID, Tonnau Cover
    In the early morning when I'm on my way to work. When I get on the gas the car would stay in neutral "reving" and no power are delivered to the wheels. It feels like the tranny is slipping. After a block or 2 the problem goes away.
    Has it happen to anyone here or is it a known problem. In the mornings is usually 30degrees around here so far and I typically only warm up the car for 5-10 seconds.
  2. Apr 10, 2009 at 5:12 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Letting the car warm up is a good place to start...Trans fluid is subject to viscosity issues the same way oil is and can cause slipping/sticking if the trans isn't properly lubed/pressured.
    Give it a shot tmrw- warm up the truck 5-10 mins before you leave and see if it's the same way.
  3. Apr 10, 2009 at 5:19 AM
    Madchild
    Bloomington MN
    5-10 minutes isn't that a little excessive?
    I was told awhile back it only take 30seconds to a minute for the car to get up and going.
  4. Apr 10, 2009 at 5:27 AM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Yeah only when the ambient temp is around 50 and above...30* is freezing point! Furthermore, your tranny will not warm up as fast as the motor. Just do the warmup-it can be a 4-5 minute one-it makes it easier for your truck.
  5. Apr 10, 2009 at 5:31 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    It takes me about two minutes of driving to get to standard temperature on the gauge in 50-60 degree weather. That's adding gas, loading the engine- If it's sitting idling in your driver way it will take longer.
    Start on the low end and see if the problem goes away....or start with 2 mins and see if the problem goes away...and work from there...It's a troubleshooting technique as much as a fix.
  6. Apr 10, 2009 at 6:22 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Have you checked the fluid level in the tranny? Sounds like it could be low. The tranny should opperate pretty normally when cold, except that it wont shift into OD until warm.
  7. Apr 10, 2009 at 6:25 AM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Did you do what SJ did? haha but chris is right, check the fluid levels!
  8. Apr 10, 2009 at 8:00 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    What year is your vehicle?
    If you have an 05-09 truck....you can't check the fluid levels as easily as the 95-04 trucks. But there is information to show you how (I don't have time to search for it)
    If you're still under warrantee...I'd call the dealer and make them check the tranny fluid and diagnose your problem. You'll have to leave it there overnight because the only way they can check the fluid, is if its completely cold.
    The tranny should never be slipping and you should always have power regardless of how cold it is.
  9. Apr 10, 2009 at 10:06 AM
    Madchild
    Bloomington MN
    I have an 09 with 600 miles on it.
