Engine Revs, But No Engagement With Transmission
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ChukarBob, Mar 7, 2018.
  1. Mar 8, 2018 at 8:12 AM
    Fett85
    Fett85 Well-Known Member
    Ohio
    2021 Tacoma TRD Off Road 4x4
    Ill give it a shot
  2. Mar 8, 2018 at 9:14 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    I mention it because low engine power can be a cause of low stall speed.
    Fett85[QUOTED] likes this.
  3. Mar 8, 2018 at 9:26 AM
    Fett85
    Ohio
    Honestly it feels like it is sitting neutral then revs up to match the appropriate speed before going into gear to avoid lurching/slamming into gear. I used to have a manual transmission in a different car and I would do the same thing. I have never felt like the truck was about to stall, but I may not be understanding what you are getting at.
  4. Mar 8, 2018 at 9:26 AM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Could it have anything to do with traction control? I've been in vehicles with traction control that drive me crazy, you pull out starting on ice in a parking lot, you're then on dry pavement and can't get any power to the wheels, super dangerous.
  5. Mar 8, 2018 at 10:58 AM
    gearcruncher
    Canadain bumper technician
    James_Bond and over60 like this.
  6. Mar 8, 2018 at 6:36 PM
    Fett85
    Ohio
    Happened in ECT too, but revved a bit higher. That indicates that this is a programming characteristic of the transmission. The power is there and I have never felt like stalling was an issue, seems like a programming thing. I haven't had an automatic for several years, but it kinda makes sense to me especially if the goal is smoother shifting.
  7. Mar 9, 2018 at 10:44 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    i drive with ECT on all the time and it does just like the video shows.
  8. Mar 9, 2018 at 5:21 PM
    Harvo
    Harvo Hanging On !!!
    17' TRD Offroad DCSB
    SpiderTrax, RCI Sliders, Warn bumper, Smittybuilt winch, Ridge Grapplers...
    Mine does this as well... but then so did my Frontier.
  9. Mar 14, 2018 at 9:56 AM
    ChukarBob
    ChukarBob [OP] Well-Known Member
    Bob
    Seattle
    2017 TRD Sport DC LB 4WD AT; preceded by '15 Subaru Outback & 2007 Tacoma SR5 DC LB 4WD AT
    I'm the OP for this thread and want to report back. Had my truck in to the dealer yesterday for its 15K ToyotaCare checkup. This issue was on my list of things to address beyond the planned tire rotation and the various inspections that come with this free service. So, the service rep suggested that their tech could take the truck on a test drive to see if he could replicate the problem. I explained that since it had happened to me only 3 or 4 times in 6 to 8 weeks of driving, it was unlikely to manifest in a 5 minute test drive by the tech. Service rep agreed and said they would check my transmission fluid level and make sure all the TSB's had been completed for my truck.
    Computer-checked the transmission fluid -- fine; all TSB's completed. I had the rep flag my concern as a safety issue, which she was reluctant to do, but did at my insistence. I'll continue to monitor for this problem. If it reoccurs, will probably escalate the concern to corporate.
    toyotatacomaTRD likes this.
  10. Mar 14, 2018 at 10:17 AM
    trazerr
    trazerr Well-Known Member
    Oregon
    2024 Tundra Plat 4x4 LB (prev 2018 DCLB SR5 4x4 and 1996 AC LX 4x4 5sp)
    Using techstream to check the transmission fluid level on a 3rd gen auto is not accurate. Transmission needs to be checked manually. Check out the giant transmission thread on this. Just an FYI!
    VB25, gearcruncher and over60 like this.
  11. Mar 14, 2018 at 10:31 AM
    James_Bond
    James_Bond Well-Known Member
    Southern California
    '16 TRD Sport DCLB
    All stock
    OP, listen to @gearcruncher, he knows Toyota transmissions like the palm of his hand.
    Before you go and waste time, ask the dealer to give you a heavily discounted trasmission FLUSH.
    That way they can clear and refill to the correct level.
    Or you can do it yourself and save yourself the headache.
    Which ever the case, the issue that you claim to have is a clear symptom of Low ATF.
    The Computer on this truck won't mark low ATF untill you are practicly dry.
    over60 likes this.
  12. Mar 14, 2018 at 10:32 AM
    ChukarBob
    Bob
    Seattle
    I've read that on TW. Problem is the dealership wants to take the easy road with TechStream. If the problem reoccurs, I plan to take truck to my preferred shop and have them check the fluid levels and all the other things that 3rd Gen owners have found problematic coming out of the factory. If the problem doesn't reoccur, I still plan to take the truck to the shop for all of these things. I've got a relationship with the GM of the dealership and think I can count on him to make things right if I find problems that should have been handled during the $25K ToyotaCare period.
    James_Bond likes this.
  13. Mar 14, 2018 at 10:33 AM
    mbezoari
    mbezoari Well-Known Member
    Marco
    Foley AL
    2016 Tacoma Limited
    Body Armor steps, Fab Fours front bumper, Rigid light bar, 4 led light blocks, weathertech liners, UWS toolbox, tint, t-rex stealth grill, HID headlights, interior led light upgrade, Winjet tail lights
    Just out of curiosity... have you all had the TSB done for the update? Mine was having issues with the transmission not engaging and the dealership local to me had a TSB. They did an update that fixed the issue. Mine wasn't exactly the same though- just a thought.
  14. Mar 14, 2018 at 11:02 AM
    ChukarBob
    Bob
    Seattle
    Yes, all the TSB's have been done.
    mbezoari likes this.
  15. Apr 10, 2018 at 11:27 AM
    #35
    trialsmm
    trialsmm Well-Known Member
    Macon,Ga USA
    16 Tacoma, TRD Sport
    Yes mine still does that after trans flash. I can't duplicate for service manager,,,,,,,,,just happens when pulling out into traffic,,,,,,,,,,,but not all the time. Scary!
  16. Apr 10, 2018 at 11:42 AM
    #36
    ChukarBob
    Bob
    Seattle
    Fortunately it hasn't happened to my truck since my original posting. Maybe it fixed itself???!!! Knock on wood.
  17. Apr 27, 2018 at 6:36 AM
    #37
    trialsmm
    Macon,Ga USA
    No, it seems to do it between 1st and 2nd? I just can't duplicate this every time I try,,,,,,,,,,,,,it happens when I least expect it,,,,,,,,,,,,,,
  18. Apr 27, 2018 at 7:08 AM
    #38
    mmatheny
    mmatheny Well-Known Member
    Dickinson, Tx
    2017 SR5 DCSB Magnetic Gray Metallic
    BakFlip MX4
    Had my truck in for other things last week, and asked about TSB for transmission -was told there wasn't one! Got my truck last August.
  19. Apr 27, 2018 at 7:16 AM
    #39
    trialsmm
    Macon,Ga USA
    The TSB would only be for the 2016, by mid-year the'16 were fixed from factory. Mine was one of the first to be delivered,,,,,,,,,,,,,,
    Lesson learned,,,,,,,,,,,,,,,,,
  20. Oct 14, 2019 at 7:12 PM
    #40
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    My truck when going around 30 - 40 mph with foot off the gas coasting around a corner then I hit the gas and truck rev up like in neutral release gas and hit gas again and all normal . Only happened maybe 5 times . Dealer said truck had stored p261093 and they did a 0013-19 software update today . Hope it's fixed now .
