Engine Revs, But No Engagement With Transmission
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ChukarBob, Mar 7, 2018.
  1. Oct 14, 2019 at 7:23 PM
    #41
    TK11
    TK11 Well-Known Member
    Tom
    N. CA
    2019 TRD OR MT
    Bilstein 6112 / 5160, 275/70/17 BFG KO2, Caliraised Sliders, SSO bumper, Warn winch
    "I'll attempt to accelerate and the engine will rev to over 3K RPM's, but there is seemingly no engagement with the transmission." Have you tried letting the clutch out sooner? Sorry, bad joke. I should've resisted. Looks like you are getting good advice here, I wish you luck in solving it.
  2. Feb 12, 2020 at 3:12 PM
    #42
    Louie del Sol
    Louie del Sol Taco Sauce
    Louie
    Long Beach, CA
    2019 Taco TRD Sport
    Any updates on this?
    My '19 TRD Sport does the exact same thing..and its been happening more frequently over the past few months. Sometimes several times in the same drive.
    Did you ever find out what the heck is goin on?
    Thanks in advance!
  3. Feb 22, 2020 at 7:13 AM
    #43
    corybantictaco
    corybantictaco Member
    My '16 TRDS started doing this over the past month or so - taking her to the dealer for the 30k service - will report back with anything interesting...
  4. Feb 22, 2020 at 7:17 AM
    #44
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    TSB 0062-18 fixed mine.
    Junkhead likes this.
  5. May 23, 2023 at 3:21 PM
    #45
    Taco19offroad
    Taco19offroad Member
    19 tacoma off road
    Mine does it also slight hill let off gas coast down slow speeds then reapply gas then revs up a lil and jerks or turning a corner some times slow speed and some times rolling stops I learned from experience to just be easy as possible getting back on the gas to minimize the jerk but shifts perfect threw all the gears any other time I think the ecu and tcm and the artifical intelligence computer goes dumb at times and realizes the last second it needs to get outta that neutrol state and get its ass in gear very annoying but I think this is just something we are all going to have to live with I also had the tranny flushed at 60k and fluid level checked and it's fine they said.
  6. May 23, 2023 at 3:36 PM
    #46
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    @TK11 you could not help it, eh??
    At least we did held out for 2 solid pages! :)
    Jokes aside - it sounds like quite an annoying issue -and a safety concern. I'd have your service rep record this as a safety issue for future reference.
    Subbed for resolution. I would have pointed to low fluid as well... (I'd confirm with the ol' 'finger method')
    TK11[QUOTED] likes this.
  7. Aug 5, 2023 at 10:05 AM
    #47
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    mine's really bad in ECT mode. It always clunks when i let off the throttle to coast, and my OBD scan tool shows it switching into open loop. Did the same thing in normal mode but went away when it stopped switching to open loop. guess it still has some learning to do.
  8. Aug 5, 2023 at 10:20 AM
    #48
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
  9. Aug 5, 2023 at 10:21 AM
    #49
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
  10. Aug 5, 2023 at 10:41 AM
    #50
    TA2016
    Oregon
    Have you checked your transmission fluid level? I had a transmission TSB done around the same time I discovered my fluid was 1 quart low from the factory. Not sure which fixed my stumble,but it went away.
  11. Aug 5, 2023 at 10:41 AM
    #51
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    yea, i've done a few drain and fills. level is perfect.
  12. Aug 5, 2023 at 10:43 AM
    #52
    TA2016
    Oregon
    Might be worth checking further on a TSB. The link I posted above was from 2018.
  13. Aug 5, 2023 at 10:49 AM
    #53
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    thanks, but i already have the latest ECU firmware
