Engine rpm drops low after startup
Discussion in 'Performance and Tuning' started by Amo-cat3, Nov 23, 2011.
  1. Nov 23, 2011 at 8:58 PM
    Amo-cat3
    Amo-cat3 [OP] Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.7" URD Pulley, APR X1, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Alcan aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, m/t atz 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    For about a week now my truck is starting up funny. Right when I crank and fire it up, it bogs down like it's going to die then slowly comes back to a normal idle. I looked at my vacuum lines and everything else looked good in the engine bay. I put the upgraded walboro fuel pump in about 3000 miles ago, could this be going bad? Anyone else have this issue or a reason for this?
  2. Nov 23, 2011 at 9:03 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    I would look at your intake air temp and coolant temp sensors. They are usually the culprits. If it indicates the engine is warm, when it isn't, it will use the warm engine fuel mix and idle settings.
    You can test them with hot and cold water and an ohm meter. The resistance should change from one to the other. Only immerse the sensor end.
  3. Nov 27, 2011 at 4:13 AM
    millerm20
    millerm20 Member
    mark miller
    charlotte NC
    08 sr5
    try cleaning the throttle body
  4. Oct 14, 2013 at 2:27 AM
    J4m3z420
    J4m3z420 Active Member
    James
    Keystone, CO
    09 DCBS TRD Off-Road V6 4x4
    OME 884x | 90021 | CS047R (minus top overload) | 60091 | LR UCA MB-TKO Wheels
    To the OP. Wondering if you figured out the problem? I have a similar problem only during a cold start. Will be cleaning the throttle body soon to try and fix.
  5. Oct 21, 2013 at 6:06 PM
    J4m3z420
    James
    Keystone, CO
    I tried cleaning the throttle body and the MAF. I still have the same problem as the OP. Will be trying some Seafoam on my next fill up to see if that fixes anything.
    Skytower: can you tell me a little more on how to check that? Even when starting my car from my garage, which usually sits around 50F in the winter, I still get similar results. Thanks
  6. Oct 22, 2013 at 3:05 PM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    MMVI 4.4L 4x4 Access Cab
    Torspd Custom Turbo kit [] Borg Warner 9180EFR Turbo [] ProEFI Pro128 EMS [] TiAL Q BOV [] TiAL V44 Wastegate @ 15psi [] CP Pistons [] CP Carrillo Rods [] ARP Head studs [] ARP Main Studs [] ARP Header - Head Studs [] Ported Heads w/ 1mm oversized valves intake/exhaust [] Brian Crower Forged Stroker Crank [] Darton M.I.D. Sleeved Block [] Kelford Camshafts [] Torspd 170* T-stat mod [] APR Large Fuel Rail [] Aeromotive Stealth 340 LPH Fuel Pump [] FueLab FPR [] APR T56 Conversion Kit [] KP RACING Built T56 [] McLeod Racing Custom Twin Disk Clutch [] One Piece Aluminum Driveshaft [] MGW Shifter [] Custom lowering kit [] Ohlins Front Coilovers [] QA1rear shocks [] Custom Ron Davis Radiator [] Dual SPAL Electric Fans []
    Please. Don't use seafoam.
  7. Oct 23, 2013 at 3:56 AM
    J4m3z420
    James
    Keystone, CO
    Why? I live in Colorado and with ethenol in our gas thought it may help?
