Engine RPMs when backing up
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mdh_us, Aug 26, 2019.
  1. Aug 26, 2019 at 3:36 PM
    mdh_us
    mdh_us [OP] Well-Known Member
    I wife just got a 2019 Tacoma Off Road the first part of the month. Has anyone else noticed when backing up, that when you first start the truck the RPMs are higher before you put your foot on the brake. Then when you let your foot off the brake the engine RPMs seem to raise a little and when you brake again they go down?
    I don't get to drive the truck other than Sundays to go to church, so it might just be me.
  2. Aug 26, 2019 at 5:10 PM
    Thedecathlete
    Thedecathlete Just Another Member
    San Diego
    2019 Cement TRD Sport 2WD
    Premium Package, Predator Tube Steps, Rough Country tri-fold bed cover, blackout badges
    I’ve definitely experienced the RPMs go up and down when I reverse after a cold start. It doesn’t even seem to be connected to depressing the brake pedal. It seems to flutter up and down regardless at times.
  3. Aug 26, 2019 at 5:25 PM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    I'm guessing putting your foot on the brakes is putting a load on the engine and releasing the brakes takes the load off causing the rpm spike before idle speed returns to normal.
    Junkhead likes this.
  4. Aug 26, 2019 at 5:42 PM
    G8R_Taco
    G8R_Taco Just passin thru….
    FLA
    2019 TRD OR 4x4
    May be a vacuum leak in the brake booster.
  5. Aug 26, 2019 at 6:00 PM
    Wire4Money
    Wire4Money Well-Known Member
    Tim
    2024 SR5 4x4 long bed
    I don’t think the off road is vacuum assisted
  6. Aug 26, 2019 at 6:03 PM
    G8R_Taco
    FLA
    2019 TRD OR 4x4
    ABS accumulator?
    Wow. Just checked. No booster! Gotta catch up. Nice accumulator.
  7. Aug 26, 2019 at 6:05 PM
    Bishop84
    Bishop84 Well-Known Member
    Normal, its trying to warm the cat's up and recharge the battery.
    Also reverse is hard due to the nature of an off set bevel differential. It takes more torque than the forward gears.
  8. Aug 26, 2019 at 6:45 PM
    mdh_us
    At least it isn't me :) Maybe I need to let it idle a little before backing out of the garage. Thanks for everyone's replies.
  9. Aug 26, 2019 at 6:52 PM
    tacoma04
    tacoma04 Retired to the lake
    Bruce
    Tennessee
    2017 TRD OR DCSB BBP
    Mine does it too with or without the brake pushed. It surges just a little when first started and backing out of the garage.
  10. Aug 27, 2019 at 7:22 PM
    mdh_us
    I got to drive the truck tonight when the wife got home, so it was already warmed up and I didn't notice the RPMs changing.
