Engine Rumble while accelerating to maintain speed
Discussion in 'Performance and Tuning' started by Hogue188, May 26, 2020.
  1. May 26, 2020 at 10:53 AM
    Hogue188
    Hogue188 [OP] New Member
    Travis
    1999 Tacoma Xtracab 4WD
    When this first started the check engine light came on and the engine rumbled horribly while accelerating, this was probably around 50-60mph. Occasionally the rumbling would stop, check engine light would blink, RPMs would drop by about 1k. After a few moments the rumbling would start again and the check engine light would go back to solid.
    About an hour later the check engine light turned off and the engine rumble had ceased. Another 30 or so minutes and the rumble would come back while giving just enough gas to maintain speed. Accelerating enough to get to around 2.5k RPMs would stop the rumbling. All of this happened without a check engine light.
    Since then the check engine light blinked on briefly with no changes.
    All of this happened yesterday. Oil levels are on the lower end of normal. Transmission Fluid is a bit over-full.
    Update: Rumble has stopped and Check Engine light is off. Plugged in an OBD Scanner and it came up with nothing. I'm guessing because the check engine light shut off. I don't trust that this won't happen again in the near future.
  2. May 27, 2020 at 11:14 AM
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    Have you checked for loose connections? Your air hoses and vacuum lines should be checked for leaks.
  3. Jul 11, 2020 at 1:43 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    almost Always helps to know engine type (trans ) + mileage
    no codes not enuf to go on
    ' rumbling / knocking ' are 2 different sounds from different locations
    either could be catastrophic
    1 guess sounds like U might be down a cylinder
