Engine running rough
Discussion in '4 Cylinder' started by Johnpdean44, Jun 29, 2022.
  1. Jun 29, 2022 at 5:49 PM
    Johnpdean44
    Johnpdean44 [OP] Active Member
    97 tacoma lx 4wd 2.7
    I have a 1997 Tacoma with a 2.7 3rz with 240.000k miles . Lately it’s been running rough and it to the point where I can’t even drive it. I heard some popping noise coming from engine . I’ve replaced wires,plugs, both 02 sensors .maf sensor . Just curious what could cause this . I’ve also checked for vacuum leaks and none seen
  2. Jun 29, 2022 at 5:56 PM
    AgentCovert
    AgentCovert Well-Known Member
    22 SR5 DCSB 2.7L
    Might as well change the egr valve just to be safe too..have you cleaned the throttle body ? Both could be completely unnecessary..maybe but it can't hurt..at least you would know it's not those..I don't know what a popping sound could be..hopefully someone else can chime in..there's been some talk about the balance shafts having problems but don't know the symptoms of such..might want to check that out..the symptoms at least here on TW to eliminate those too..best of luck..I'm assuming the spark plugs are good right ? Doubt the timing chain has a problem but if you happen to have the value cover off it wouldn't hurt to just grab it to see if there's slop in it..
  3. Jun 29, 2022 at 5:57 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Do you have a check engine light on?
    I wouldn’t replace any more parts until I did a bit of diagnostic.
    Replacing parts at random can cost more than the cost of a diagnosis at a shop.
  4. Jun 29, 2022 at 5:58 PM
    saint277
    saint277 Vigilo Confido
    May need some timing work, has it ever been looked at?
  5. Jun 29, 2022 at 6:14 PM
    Johnpdean44
  6. Jun 29, 2022 at 6:17 PM
    Johnpdean44
    No cel on
  7. Jun 29, 2022 at 6:17 PM
    Johnpdean44
    Compression is good across the board -210 each hole
  8. Jun 29, 2022 at 6:19 PM
    Johnpdean44
    I’ve noticed when cold it runs fine but when Warm it starts acting up
  9. Jun 29, 2022 at 6:19 PM
    MGMDesertTaco
    Sounds like a fuel issue. Scan for codes?
  10. Jun 29, 2022 at 6:21 PM
    Johnpdean44
    No codes…
  11. Jun 29, 2022 at 6:24 PM
    MGMDesertTaco
    Could be fuel pump, fuel line or injector related.
  12. Jun 29, 2022 at 6:25 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Stuck egr, maybe
  13. Jun 29, 2022 at 6:25 PM
    MGMDesertTaco
    Are all the plugs and plug wires/ 02 sensors tight? Did you recheck your maf connection?
  14. Jun 29, 2022 at 6:27 PM
    Clearwater Bill
    Billy
    Largo Florida
    Compression test
    Smoke rest for vaccum leaks
    Check for cracked or leaking exhaust manifold
    Check timing
  15. Jun 29, 2022 at 6:39 PM
    GarrettTacoma
    GarrettTacoma Well-Known Member
    2022 2.7L SR DCSB 2022 TRD OR DCLB
    Would a 1997 Tacoma with a 2.7 3rz have valve shims that could need adjusting? Also definitely check / replace EGR.
