Engine seized 1,000 miles after oil change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ParalegalBarbie, Aug 30, 2024.
  1. Aug 31, 2024 at 7:41 PM
    #181
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    So what is the ending? Jiffy filled the tranny? Never filled the oil?
  2. Aug 31, 2024 at 7:48 PM
    #182
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    Yeah she answered that a few pages back and said her truck has a distinctive bed liner or something so she is sure it was her truck in the video.
  3. Sep 1, 2024 at 6:18 PM
    #183
    ParalegalBarbie
    ParalegalBarbie [OP] Well-Known Member
    2013 Taco 4 cylinder
    Haven't figured it out yet. My mechanic is off for the Labor Day weekend. Plan to share some of the ideas from this thread with him on Tuesday. I will update if we learn anything new. Thanks everyone for the help!
  4. Sep 3, 2024 at 2:14 PM
    #184
    DailyTacoMD
    DailyTacoMD Well-Known Member
    Jeremiah
    2006 2.7L AC 4x4 5spd
    From a legal standpoint it could certainly be suggested that their failure to complete the other checkpoints could be indicative of the attention to detail with the oil change itself.
    Drainplug and washer definitely look suspect and as someone else mentioned previously, are the washer & plug correct and correctly installed? And why was it not noted in the service comments? Suspicious…
    seems the most likely scenario is that the barrel burped out a bit of oil before emptying out, causing a small amount of oil that burned/broke down over the course of your travels. If the dipstick check was not clearly “remove, wipe, reinsert, remove to check, and reinsert” then they would’ve missed the error. Not to mention, way too many people involved.
    I used to manage a Walmart that had a service shop. Standard procedure was 1 tech in the pit doing the drain plug & filter, 2nd tech topside doing the fill & level check, the Service Mgr/Supervisor was required to be a secondary check for oil level and sign off before closing the ticket. Whenever there was an issue with a pre-existing leak, road damage, or damaged/cross-threaded plug the tech was required to report those issues prior to removing the plug or beginning any work on the vehicle. Obviously auto service isn’t WMs primary business so I’d like to think that a company that “specializes” in those services would have a consistent routine in place.
    I had a friend who lost a motor to jiffy lube some years back because of a similar issue but her claim was denied based on the fact that she was “street racing” (a stock Honda civic with window tint and a fart can muffler).
    All reasons I’m happy to do my own work unless it’s something I can’t handle without specialized tools or a lift.
    OP I hope you get some resolution on this but the outcome is usually not what it should be. Best of luck and please update on final disposition. :fingerscrossed:
    Road_Warrior and skee like this.
  5. Sep 3, 2024 at 2:52 PM
    #185
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    I still check this thread daily to see if we have a resolution!
    Tacos4ever15 likes this.
  6. Sep 3, 2024 at 2:56 PM
    #186
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    IF I paid someone to do an oil & filter change I would check the work and ensure the engine has oil to a proper level before leaving the garage.
    I used the 24 months of "free" oil changes when I bought my truck. They were always offended when I checked the oil and verified the filter was replaced before leaving...
  7. Sep 4, 2024 at 11:10 AM
    #187
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    I changed my oil yesterday and after reading this thread, I checked the oil again today.
    Sorry about the blown engine. Never a good thing.
  8. Sep 4, 2024 at 11:54 AM
    #188
    TacoTuesday1
    FL
    >took it to Jiffy Lube
    >engine blew
    Correct.
    O'DubhGhaill, Tronfunkblow and 69 Jim like this.
  9. Sep 4, 2024 at 12:20 PM
    #189
    RCBS
    RCBS Well-Known Member
    Harden your bark, there are storms on the horizon.
    Pull the filter and cut it open. Is it wet? If not, no oil went in. I would believe that the 4.0 would run for 1000 miles on residual after knowing a guy who ran one to 46,000 miles on the factory fill before no worky no more. (old guy and dementia was setting in)
  10. Sep 4, 2024 at 4:12 PM
    #190
    1 Limited Toyota
    1 Limited Toyota ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
    Oh crap you made me laugh!
    RCBS[QUOTED] and O'DubhGhaill like this.
  11. Sep 4, 2024 at 4:30 PM
    #191
    Waasheem
    Waasheem
    2007 xrunner
    Post quickie lube oil change failures are common. A honda dealership tech told me they get at least 3 per month. Oil filter or drain plug fell off or they forgot to put in oil.
    It doesn’t sound like the oil level was checked after they did it. No disrespect intended here. Is it possible the dash light came on and wasn’t noticed? That light is working?
  12. Sep 4, 2024 at 5:22 PM
    #192
    545
    545 Well-Known Member
    2015 Access Cab
  13. Sep 5, 2024 at 7:47 AM
    #193
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    None of this matters,the O.P is in need of a new motor.
    RCBS likes this.
  14. Sep 5, 2024 at 8:29 AM
    #194
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    I was thinking the same but assumed the owner would have noticed the oil light being on immediately. But, perhaps that sensor or light isn't working. :confused:
    TireFire likes this.
  15. Sep 5, 2024 at 3:27 PM
    #195
    1 Limited Toyota
    California
    08 XRunner
    As years of doing smog check in my long gone past, I can say its alarming the amont of people that drive around unaware of a CEL thats been lit.
    Jimmyh likes this.
  16. Sep 5, 2024 at 3:57 PM
    #196
    clenkeit
    Colin
    Lakewood, CA
    OP already stated that the oil light did not turn on. So clearly he's not one of those guys.
  17. Sep 5, 2024 at 4:04 PM
    #197
    DailyTacoMD
    Jeremiah
    actually it does… quite a lot when a new motor installed probably costs 1/2 the value of the truck
    OP already knows the new motor is needed, sounds like sorting that part has already started, however having valid concerns & talking points/substantial evidence is the only shot at getting JL to own up to the mistakes and recoup costs in this ridiculous situation…
    If it were you, would you fight the fight or just bend over & open your wallet?
    HisDad, birry, BKinzey and 1 other person like this.
  18. Sep 5, 2024 at 4:16 PM
    #198
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    She's definitely not one of those guys.
  19. Sep 6, 2024 at 1:02 PM
    #199
    lynlan1819
    Tacoma
    Lifted
    I work for the court system,so I think I know more about law then most,it's hearsay when she said the truck sat for 11 days, JL is not going too pay for anything,and any court will not help after she had the truck for 11 plus days before the failure,just saying.
    I feel for her but facts are facts.
    winkel likes this.
  20. Sep 6, 2024 at 2:24 PM
    #200
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    If it's her truck and she knows exactly where it was, how does that qualify as hear say? JL may try to refute that by trying to make her substantiated her statement.
    If she has witnesses that can attest to her statement, she might prevail.
    JL undoubtedly has counsel that has a lot of experience defending against claims for their shoddy work, so it's likely they know how to proceed.
    OTOH, she works for a lawfirm so it may not cost her much to pursue her claim.
    We might never know as all too often first time posters with problems disappear never to return.
    O'DubhGhaill likes this.
