Engine seized?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Onethirtyeight, Jul 13, 2023.
  1. Jul 13, 2023 at 8:23 AM
    Onethirtyeight
    Onethirtyeight [OP] Well-Known Member
    Nigel
    Maui, HI
    99 Tacoma 3.4 TRD
    99 3.4 was driving and it broke down, towed it home. I cannot turn the crank with a breaker bar. The truck moves freely in neutral and also in gear, I’ve read the truck wouldn’t move if the motor was seized or frozen. Is it possible my starter motor froze up and won’t let the flywheel spin and that makes it so crank won’t turn by hand?
  2. Jul 13, 2023 at 8:32 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    just what kind of failure did you have?
    Broke down can include so many possible failures.
    I take it the rear axle is off the ground or the rear drive shaft is removed.
    Pretty hard to move any vehicle in gear with the drive line installed and on the ground.
    With the spark plugs installed and good compression depending on your size a 4' breaker bar might not turn the engine.
  3. Jul 13, 2023 at 11:02 AM
    Onethirtyeight
    Nigel
    Maui, HI
    99 Tacoma 3.4 TRD
    The truck just shut off, had a bad battery but I replaced that and it still just clicks when trying to start. So I trying turning the crank pulley bolt while in neutral and won’t budge
  4. Jul 13, 2023 at 11:03 AM
    Onethirtyeight
    Nigel
    Maui, HI
    99 Tacoma 3.4 TRD
    Never took off the drive shaft I’ll have to check to make sure it’s still there
    skeezix likes this.
  5. Jul 13, 2023 at 8:11 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Does it have oil in it?
    Engines don't typically seize for no reason, you may also want to remove the belts and make sure a pulley isn't locked up.
  6. Jul 13, 2023 at 11:19 PM
    Onethirtyeight
    Nigel
    Maui, HI
    99 Tacoma 3.4 TRD
    It’s got oil, also I messed up it moves in neutral, not in gear. Had the t case in N. Oops. Also I just pulled the starter and bench teaser was good. Maybe there’s another wire for ignition on to starter I’ll have to dive in tomorrow
    1blink likes this.
  7. Jul 13, 2023 at 11:24 PM
    Bivouac
    I would check your battery voltage .
    Make sure the terminals are clean and tight.
    Check for a good main ground connection.
    Being a 99 have the battery cables every been changed??
    Battery Cables do break down with time.
    Good luck!
  8. Jul 15, 2023 at 7:08 PM
    1blink
    1blink Well-Known Member
    Storm Mtn, CO
    2000 3.4 manual SR5
    That's good news!
