Engine shaking, Troubleshoot and possible diagnosis?
Discussion in 'Performance and Tuning' started by amocatoyo, Feb 8, 2015.
  1. Feb 8, 2015 at 8:40 PM
    amocatoyo
    amocatoyo [OP] Member
    White lightning
    Good evening to all Tacoma drivers/owners!
    I have an issue with my '06 4.0 Tacoma. When I first purchased the vehicle it ran perfectly fine. About a few months after driving it the engine would shake during acceleration and sometimes even when easing of the throttle. I noticed the RPM would drop below 1500 and that's when the shaking would start. Eventually it would stop if when I step on the throttle again but I've experienced this shaking from 30mph, to 40mph, and now even 50mph. It seems to be getting worse.
    I would greatly appreciate any ideas on how fix this problem before it worsens.
  2. Feb 9, 2015 at 7:54 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Any check engine lights?
  3. Feb 9, 2015 at 8:24 AM
    amocatoyo
    White lightning
    The maint reqd light pops up for about a minute then goes away.
    I feel like it might be a trans issue but I'm unsure.
    I'm getting it checked on Thursday.
  4. Feb 9, 2015 at 8:25 AM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Check your motor mounts.
  5. Feb 9, 2015 at 9:30 AM
    amocatoyo
    White lightning
    Thanks everyone. I'll check the mounts. If anyone else has more ideas on what it could be that'd be great to get more input. Have a good day!
  6. Feb 9, 2015 at 10:18 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Does the problem only happen while driving, or also while idling? As in, can you rev the engine and feel it stumble at a certain RPM?
  7. Feb 9, 2015 at 5:42 PM
    amocatoyo
    White lightning
    Just discovered it does shake also at idle but not at initial start up. But I was at the stop light without the A/C on and it was shaking just like when I'm coasting and the rpm drops. It only shakes if the truck is moving. If I ease off the throttle it drops under 1500 then shakes until I step on the pedal again.
  8. Feb 10, 2015 at 4:53 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    How many miles does the engine have?
    Also, you said it shakes at idle, and it only shakes if the truck is moving. I'm confused by this.
  9. Feb 10, 2015 at 5:52 PM
    amocatoyo
    White lightning
    Apologies for the improper communication on my part. Trying to reply on a smartphone during a rushed moment doesn't help.
    145k miles
    Shook on idle @ the stop light yesterday. Does NOT shake during initial start up.
    Here's a scenario I have every day. When I'm accelerating, regardless if I have a heavy load or not at about 30mph if I ease off the gas pedal, the truck will start shaking (happens when the rpm drops to 1500rpm or below). The shaking has occured so far at 30mph, 40mph, and 50mph.
  10. Feb 10, 2015 at 8:15 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    First thing I can think of, is to check all of your vacuum hoses for cracking. They may or may not have some, which could also be a separate culprit. If not,there is a possibility t it won't be long until they do start cracking, due to the heat cycles and age.
    Has your transmission's ATF ever been changed? If not, then it needs to be done, and Toyota has a flush service if you don't want to do that yourself. Should have actually been done closer to 100k. This is just PM stuff that i am mentioning. Good to do but not necessarily related to the issue.
    Also, take a look at your carrier bearing. It is possible that it is worn out and causing vibes.
    Lastly depending on the type of wheels you have, the wheel weights could have come off.
    With what little information that has been listed, it is hard to give an a cute answer. At least you have some more things to check though.
  11. Feb 11, 2015 at 8:48 AM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    When you ease off the gas pedal, normaly the FI switch to fuel cut and then will switch back to closed loop in iddle mode at 1400 rpm or close.
    You dont have an AFR gauge? If yes, you would probably see a strange behavior of the AFR. It can be the symptoms for a lot of different things like: Injectors, fuel pump, pressure regulator, O2 sensor, throttle body actuator.
    In the same period the motor start to shake, have work on/touch the truck?
  12. Feb 13, 2015 at 11:25 PM
    amocatoyo
    White lightning
    So I took the truck to the shop. I had it diagnosed and it turned out to be that the tires needed to be rotated. They're not the standard radial tires but they're huge mud tires that came with the truck when I purchased it. The mechanic said it could've been the truck having so much traction that when easing off the pedal, the tires were already worn due to the weight haul each day. Guess that was it. Thanks for all your help everyone!
