Engine Shaking when gas pedal pushed with Video.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RustedTaco703, Oct 25, 2025.
  1. Oct 25, 2025 at 1:32 PM
    RustedTaco703
    RustedTaco703 [OP] Active Member
    2006 Silver Tacoma
    Hello,
    06 2.7L Tacoma
    2WD
    Noticed this morning at a stoplight some small shakes of the engine as I took my foot of the brake to inch forward. The vibrations then went away as I got up to speed, and came back at the next stoplight. I was close enough to home to turn around. Since I got back, I restarted the car, RPM's now idle around 600-800 in park, and then as I reverse out the driveway slowly, the shakes come back, and then proceed to go away as I drive down the street.
    Going through forums I see it could be ignition coil, engine or tranny mount, spark plugs, or even an air flow issue.
    I have attached a video of the engine shaking, this shakes as the pedal is pushed.
    https://youtu.be/nUhuloKVxqc
    Worth risking driving to AutoZone to try and get codes? Do the sounds indicate any issue?
    Thank you.
  2. Oct 25, 2025 at 1:39 PM
    BabyBilly
    BabyBilly Well-Known Member
    Billy
    2020 Pro
    Have you checked the motor mounts?
    RustedTaco703[OP] and Shelf Life like this.
  3. Oct 25, 2025 at 1:48 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    That's a misfire, need to find out which cylinder it is.
    Jimmyh likes this.
  4. Oct 25, 2025 at 1:52 PM
    notbythebook
    notbythebook Well-Known Member
    2011 2.7 4x4 SR5
    Snow plow
    I've always found that mine has a hard time relearning its idle whenever the weather changes. As long as it has oil, its safe to run. Bring it up to operating temperature and drive it around a bit and see if it eventually self corrects. If it is a misfire rather than just idling too low, it will throw a code after a few times, which should indicate which cylinder is giving you a hard time.
  5. Oct 25, 2025 at 2:25 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Ima gonna go out on a limb and say spark plug tube gaskets. :rolleyes:
  6. Oct 25, 2025 at 3:50 PM
    RustedTaco703
    2006 Silver Tacoma
    Good idea, I will snag some photos of those I just gotta watch a vid to make sure I know where to look, I will snag some photos and post.
  7. Oct 25, 2025 at 4:11 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    100% an engine misfire. Always start cheap and easy, find which cylinder is missing, then plugs, then wires, coils on up to injectors. Pull plugs and the tubes are full of oil, valve cover gasket/plug seals. Next would be scoping the engine cylinder/piston tops/valve heads and taking a compression reading. Hopefully you don't need to go that far.
    GilbertOz and BabyBilly like this.
