engine shudder when starting off
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bobbybreach, Aug 13, 2013.
  1. Aug 13, 2013 at 4:39 AM
    bobbybreach
    bobbybreach [OP] Well-Known Member
    bobby
    westchester NY
    09 TRD
    my engine will shudder when i start off in first when its a cold engine. i read there is a TSB on it and i cant find it anywhere. if someone knows where that TSB is please let me know. another TW member had it done and he said it hasnt had it since.
    thanks
  2. Aug 14, 2013 at 6:45 AM
    bobbybreach
    bobby
    westchester NY
    09 TRD
  3. Aug 14, 2013 at 6:50 AM
    BamaToy1997
    Bill
    Navarre, FL
    First off, have you done a search on TW for information? I know there are several threads that have discussed this shudder, and where to find help.
    Second, could you describe a bit more this shudder. Are we talking a jerking motion after the clutch is fully engaged as you accelerate, or a shudder as the clutch is being applied? Each one is different.
  4. Aug 15, 2013 at 3:04 AM
    bobbybreach
    bobby
    westchester NY
    09 TRD
    Yes I have done the research. And it's a shutter when I'm releasing the clutch as I'm pulling away in first gear. It only does it when it's a cold engine. Meaning the engine is cold regardless of the whether temp
