ENGINE SHUT DOWN
Discussion in '2nd Gen. Tacomas (2005-2015)' started by john arnest, May 24, 2015.
  1. May 24, 2015 at 4:40 PM
    john arnest
    john arnest [OP] New Member
    2006 tacoma 4x4 auto longbed
    DRIVING MY 2006 TACOMA 4X4 4 DOOR LONG BED YESTERDAY (5/23/15) SHUT DOWN IN TRAFFIC. AFTER TOW HOME THE FOLLOWING:
    1. CANNOT REACH ECM WITH SCANNER (ERROR- UNABLE TO CONNECT)
    2. FUSES SEEM TO BE ALL RIGHT BY PULLING AND RESISTANCE CHECK.
    3. NO POWER IN OR OUT AT FUEL PUMP RELAY.
    ANYBODY GOT ANY IDEAS? APPRECIATE THE FEEDBACK
  2. May 24, 2015 at 4:59 PM
    john arnest
  3. May 24, 2015 at 5:20 PM
    Clearwater Bill
    Billy
    Largo Florida
    Do you have access to another scanner to try, just to make sure it's not that? Or at least verify your scanner operates on another vehicle?
    What other electrical symptoms are there? Lights, cranking (no start of course), utter nothingness, etc.?
    Any aftermarket electronics like alarms/immobilizers? Factory immobilizer? Ignition switch worn out (janitorial key ring, many miles on vehicle) ?
    Load test battery? (not enough info to tell if it's an issue or not, so tossing that in too)
    Pre shutdown symptoms/behaviors? Bucking, surging, etc.?
    More info will allow better guessing.
  4. May 24, 2015 at 8:00 PM
    smd3
    smd3 Well-Known Member
    I've seen other posts where mechanics had issues talking to the ECU with their scanner. In at least one instance there was a wire loose/pushed back from the connector under the dash.
    In these cases it was during an emissions check.
  5. May 25, 2015 at 4:15 PM
    Drivesector
    Drivesector Well-Known Member
    TRD sport
    Does the dash light up when you turn on the key?
  6. May 26, 2015 at 8:18 AM
    john arnest
    Thanks all- turns out some one had put a 10A fuse in the slot for the EFI which was supposed to be 20A- I missed it when I was checking fuses- all good now
  7. May 26, 2015 at 8:20 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Good catch.
  8. May 26, 2015 at 8:32 AM
    toomanytoys84
    toomanytoys84 Well-Known Member
    Stock
    That was an obscure problem. Good job finding it!
  9. May 26, 2015 at 5:48 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    So it was a blown EFI Fuse?
