Engine shut off on steep incline
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Softtaco20, Dec 30, 2023.
  1. Dec 30, 2023 at 11:01 AM
    Softtaco20
    Softtaco20 [OP] Tacoma that rides like a wagon
    Brad
    Somerset,Kentucky
    Ambassador for toyotaover landers/global Overlanders yotaverse - raptor lights rhinousa - recovery gear auxbeamlighting - 5 inch pod lights auxito - hi/lo headlights ionwheels - wheels mesocustoms - interior blackout greenmax - 33x10.50r16 tires tackform - mounting system bulletpointmounts - radio mounting system tacogarage - snorkel ebcbrakes - break kit tacovinyl - scoop/hood black out spyderauto - taillights roughcountry - 3 inch lift oldmanemu - diff drop caliraised - light bar
    It's happened a few times most recent was on a trail in Tennessee called thrash rock. Truck was in 4lo over 30° uphill angle. Made it halfway before the Trans temp light came on and low oil pressure I had to stop to position for a climb over a rock truck immediately shut off breaks got stiff and started sliding luckily support rope caught me. No where to trun around it took a gladiator strapped to a tree winched to a rubicon strapped to me to pull me level once level I let the truck stand by for 10 minuets started right up no smoke no engine noises and finished the trail. Anyone experienced this. Seems dangerous if your in a spot to use breaks and can't because the piston pressure.
    Superdave1.0 likes this.
  2. Dec 30, 2023 at 11:04 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Do it a few more times and you’ll send a rod through the block. These are offroad* trucks.
    wilcam47, JasonLee, Junkhead and 3 others like this.
  3. Dec 30, 2023 at 11:10 AM
    TacoPandaTRD
    TacoPandaTRD Well-Known Member
    TacoPandaTRD
    Chilliwack, British Columbia, Canada
    2020 Toyota Tacoma TRD Off-Road
    Always looking to modify! Check out my Instagram @TacoPandaTRD
    I have heard about this but it’s never happened to me. I installed a J&L oil separator to relieve pressure on the crankcase and prevent flooding the intake manifold. I’ve been on some steep inclines and even stopped to look back and wait for buddies to catch up and never once had an issue.
    bulalo likes this.
  4. Dec 30, 2023 at 11:21 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    The old Land Cruisers would do 46% according to specs and I've been there a few times in the past. 30% and troubles is pretty poor.
    TacoPandaTRD and Superdave1.0 like this.
  5. Dec 30, 2023 at 11:48 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Couple questions- Does the outlet line from the J&L oil separator return back to the intake manifold, or where does it go? Also, how full has the container been after climbing your steepest hills? And have you needed to use the larger sized catch can?
  6. Dec 30, 2023 at 5:28 PM
    bbal
    bbal Well-Known Member
    Oil starvation at 30 degrees? My driveway is probably 30, as well as the top of my street where I wait at a stop sign. Seems odd…
    OG_Tacoma likes this.
  7. Dec 30, 2023 at 5:50 PM
    Mbtstaco
    Mbtstaco Well-Known Member
    2023 Tacoma Pro MGM
    Were you sitting at the high angle for awhile stationary before everything went fubar?
  8. Dec 30, 2023 at 5:58 PM
    Softtaco20
    Brad
    Somerset,Kentucky
    Yes it was probably a 10-15 minute climb after waiting my turn and being spotted
  9. Dec 30, 2023 at 5:59 PM
    IronMaidenJapan
    IronMaidenJapan So old I fart dust
    Lizardville
    23 TRDOR
    Any other Tacoma's in your group or on the same trail with the same issue?
    I don’t think that angle would be considered extreme.
  10. Dec 30, 2023 at 8:30 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Check for air leaks, cracked rubber couplers, and looseness around the intake. Usually this is easily diagnosed with a smoke machine. When the engine is heavily loaded, it flexes the engine mounts and pulls on the intake tube. Because the airbox is body-mounted, this can cause temporary gaps, and the engine shuts off from the massive vacuum leak. Do you have an aftermarket intake? They are more prone to this.
    When the engine stalls, the trans temp warning and oil pressure light will always come on.
    30° uphill isn't much to cause oil starvation or oil burning issues. The stock truck can handle 30° side tilt without lifting tires.
  11. Dec 30, 2023 at 9:46 PM
    Softtaco20
    Brad
    Somerset,Kentucky
    The truck has a snorkel but factory air box but it didn't have it at the time and only had around 30k miles also the lights came on before the engine shut down
  12. Dec 30, 2023 at 9:51 PM
    Softtaco20
    Brad
    Somerset,Kentucky
    Yes I'm assuming 30 it was at a pretty steep incline enough when it shut off I hit the breaks they went stiff and it slid till the security rope caught me
  13. Dec 30, 2023 at 9:59 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I ran over a stone at a Taco Bell drive thru, once.
  14. Dec 30, 2023 at 11:17 PM
    Softtaco20
    Brad
    Somerset,Kentucky
    Hope they gave your money back!
    Junkhead and Steves104x4[QUOTED] like this.
  15. Dec 31, 2023 at 12:43 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    the brakes will not be vacuum assisted (or boosted) when the engine dies, on the non OR and Pro models anyways, so the brake pedal will be stiff.
    wilcam47 and Junkhead like this.
  16. Dec 31, 2023 at 1:53 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    It’s best not to stay on a 20+ degree slope (either axis) with the engine idling for a long period of time. The engine can suffer from oil starvation.
    Mbtstaco and wilcam47 like this.
  17. Dec 31, 2023 at 1:59 PM
    bbal
    Just my opinion but it seems like any vehicle sold as or touted as “off road” should have measures in place to deal with the engine running at grade. This seems like a 911 GT2 being sold without a dry sump and then hearing that you should just go a little easier in the corners. We’re talking 20-30 degrees which isn’t much different from a steep hill in SF. This truck should be able to handle this.
    TacoPandaTRD likes this.
  18. Dec 31, 2023 at 2:21 PM
    gudujarlson
    Minnesota
    I appreciate the sentiment, but I think you might be underestimating a 30 degree incline or perhaps confusing it with a 30% incline.
  19. Dec 31, 2023 at 2:32 PM
    bbal
    Yeah I suppose it’s pretty steep. Maybe instead of “off road” it should be called “can be carefully taken off pavement sometime”
    Softtaco20[OP] likes this.
  20. Dec 31, 2023 at 2:39 PM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    I think the key here is idling. Don’t do it on steep slopes. The climb to La rinconada in Peru if you come up the east side of the mountain that’s not paved far exceeds 30 degrees in places. And I can verify the truck will handle that and a plus 30 sideways lean without shutting off.
    Irons, Canadian Caber and Junkhead like this.
