Engine shut off while driving - cranks but wont start
Discussion in 'General Tacoma Talk' started by v-cross1, Nov 8, 2024.
  1. Nov 8, 2024 at 4:00 AM
    v-cross1
    v-cross1 [OP] Member
    Jeff
    07 Tacoma
    Hello, my name is JT and I'm new to the forum. I just purchased an 07 Tacoma with a 4 liter V6 (200k miles). While driving home from purchase at 60 mph, the engine cut off (luckily I was able to pull off the road!). The engine cranks freely but it won't start. Any help would be greatly appreciated.
  2. Nov 8, 2024 at 4:26 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Does your check engine light come on with the key on?
  3. Nov 8, 2024 at 7:04 PM
    v-cross1
    Jeff
    07 Tacoma
    Yes, the check engine light comes on when I turn the key. When I purchased it, the check engine light was on and there were 3 codes:
    P0116 and P0117 (engine coolant temp sensor)
    P0301 (cylinder 1 misfire).
    The truck still was drivable, but developed a miss once moving.
    My goal was to drive it home and work on it - I was about 3 miles from home when the engine cut off while driving.
  4. Nov 8, 2024 at 7:09 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    That's kind of concerning, it didn't overheat did it?
    Have you checked the coolant?
  5. Nov 8, 2024 at 7:15 PM
    v-cross1
    Jeff
    07 Tacoma
    Yes, I checked the coolant and it was ok.
  6. Nov 8, 2024 at 7:20 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Well that's good, often when I see the P0117 code on Toyota's it set because of an overheat not a bad sensor.
    Do you have a scan tool that can read live data?
    If so bring up RPM and verify you have a reading around 150-200 RPM while cranking.
  7. Nov 8, 2024 at 7:45 PM
    v-cross1
    Jeff
    07 Tacoma
    I just took a closer look at the radiator and noticed that the stem where the overflow bottle connects to the radiator is snapped off! The bottle contains coolant, but its not connected to the radiator. I removed the radiator cap and cant see any coolant at the top of the radiator, so it's probably pretty low. I hope I didn't kill the engine- it still cranks.
  8. Nov 8, 2024 at 7:49 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    That's not good, crank it over with the cap off and see if it's huffing smoke/steam out of the radiator. If it is it's probably toast, if it's not maybe it's ok.
  9. Nov 8, 2024 at 7:52 PM
    v-cross1
    Jeff
    07 Tacoma
    I'll fill the radiator with water and the crank the motor - if I see bubbles then I know it's toast.
    Dm93 likes this.
  10. Nov 8, 2024 at 7:56 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Hopefully that's not the case:fingerscrossed: but with the codes and symptoms I'm concerned it may be.
    If not we can troubleshoot this further.
    soundman98 likes this.
  11. Nov 8, 2024 at 7:58 PM
    v-cross1
    Jeff
    07 Tacoma
    Sounds good. Thanks.
  12. Nov 9, 2024 at 8:08 AM
    v-cross1
    Jeff
    07 Tacoma
    Well, my worst fears are confirmed - I filled the radiator with water left the cap off. When I turned the key, water erupted out of the opening - blown head gasket I assume?
  13. Nov 9, 2024 at 8:51 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Almost certainly but I'd be more concerned about the head/deck being warped, aluminum engines don't handle overheating very well at all.
    The heads can be milled a tiny bit but you have to compensate the removed material by using a custom headgasket to make up for the amount taken off or you will likely get timing codes.
    If the deck of the block is out of spec there's not really anything that can be done with it.
  14. Nov 9, 2024 at 1:01 PM
    v-cross1
    Jeff
    07 Tacoma
    Thanks. I've 1already started looking for a replacement engine. If anyone has a used 4.0 1GRFE engine (5th digit U) in the northern VA area, please contact me.
  15. Nov 9, 2024 at 8:00 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  16. Nov 9, 2024 at 8:18 PM
    Jasskillman
    Jasskillman Well-Known Member
    SoCal
    2013 DCSB
    I would have a few questions for the person you bought it from..
  17. Nov 9, 2024 at 9:56 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    it sounds like he went into it knowing about the codes displaying, so the engine having issues might have already been accounted for in the agreed-upon sale price.
  18. Nov 10, 2024 at 12:00 PM
    v-cross1
    Jeff
    07 Tacoma
    That's correct - it was super-cheap for a reason!
