engine shut off while driving
Discussion in '1st Gen. Tacomas (1995-2004)' started by lipcurl, Feb 5, 2011.
  1. Feb 5, 2011 at 7:08 AM
    lipcurl
    lipcurl [OP] Member
    brian
    sc pa
    95.5 4x4 tacoma
    hey guys. just picked up an 95.5 reg cab, 2.7, 5 speed with 165k in great condition. what a great forum this is, soooo much info available. anyways last week while driving the engine cuts out on me and the check engine lite comes on. i coast to a stop and try to start it and it fires right up and has been running fine ever since but the check eng lite still on. any ideas on what to check for???????
    not obd2 so no autozone for free scan
  2. Feb 5, 2011 at 7:39 AM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    Sounds fuel related, try changing your filter possibly.
  3. Feb 5, 2011 at 4:44 PM
    kingB
    kingB Member
    nc
    2002 sr5 2.7l tacoma 4x4
    k&n air filter/stock 2.7l
    exactlly! did it sputter at all? or just kill out?
  4. Feb 5, 2011 at 4:47 PM
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
    ^^this, or maybe spark. any idea when the last time plugs were changed?
  5. Feb 5, 2011 at 4:53 PM
    mrp192
    mrp192 REALLY!!
    Brent
    Cheney WA
    98 V6 4x4 limited
    Stereo, boobies
    It could be your fuel pump..
    BUT do the easy first.. change your spark plugs, spark plug wire, cap, rotor, fuel filter and Get your timing checked.. If you still have your problem then i would change your fuel pump.
  6. Feb 5, 2011 at 8:04 PM
    kingB
    kingB Member
    nc
    i agree with mrp execpt im sure if timing were off you would aquire the problem for frequently. also check all your ground straps. i have seen some funny stuff over the years! im also a first time taco owner but grounds are very important as i have learned and im an mechanic. so do yourself a favor and do an extended tune up as mrp had said! this is almost always the first step unless u have obd2 which will shoot u in a closer position.
  7. Feb 6, 2011 at 3:08 AM
    lipcurl
    lipcurl [OP] Member
    brian
    sc pa
    95.5 4x4 tacoma
    thanks for the help guys. i now have a good starting point
