Engine shut off while driving
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sphornet, Sep 21, 2021.
  1. Sep 21, 2021 at 8:42 AM
    Hextall
    Hextall Well-Known Member
    NH
    17 Inferno OR DCSB
    While coasting in neutral, there's no load on the engine, so the computer is likely trying to feed as little fuel as it can to keep it running/turning. Probably a couple of ill timed burps in that feeding and you stalled.
    I get the desire to put in neutral while going downhill, it just seems to "feel" better. It does use more fuel relative to keeping it in gear and foot off the throttle, but I could see how increased RPMs while you're trying to be in stealth mode could be annoying to the experience. Not as annoying reading whines about threads going off topic, but annoying nonetheless.
  2. Sep 21, 2021 at 8:44 AM
    sphornet
    sphornet [OP] Active Member
    Thanks. I rarely coast down hill either. I just happened to be in an area where I was curious to see what would happen. I certainly didn't expect the engine to cut-off. Reaching out to the dealer now. Stay tuned for updates.
    Anton338 likes this.
  3. Sep 21, 2021 at 8:45 AM
    bonifacio_629
    bonifacio_629 Well-Known Member
    Walther
    Virginia
    2018 Tacoma TRD Sport, 6MT 4x4 DCSB, Inferno
    Predator steps, TRD cat-back, lots of orange stickers.
    This thumbnail made me click on the post. It hasn't disappointed. Also it's been very disappointing.
    Beerpayzdabillz likes this.
  4. Sep 21, 2021 at 9:27 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Deceleration down hill, the engine shuts off the fuel injector to produce compression braking. Putting the transmission in neutral makes the engine try to idle, burning fuel.
    It also isn't uncommon for clutches to explode from overspeed when trying to re-engage the tranny and getting the wrong gear in a rush. Not something I would do on a hill. I hold a gear or drop a gear as necessary but never put it into neutral.
  5. Sep 21, 2021 at 9:33 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Coasting in neutral does not save fuel. On modern vehicles going back years now, the ECU cuts fuel to the injectors when you're off the accelerator...helps auto manufacturers meet federal emissions requirements for vehicles.
    Going in a lower gear instead both saves your brakes and also doesn't hurt fuel economy if you're off the accelerator. Much safer too, don't have to suddenly go back into gear in an emergency maneuver.
    xxTacocaTxx and Hobbs like this.
  6. Sep 21, 2021 at 9:45 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I don't disagree with you and think that DFCO is a cool thing.
    That said, there is a small overlap where engine braking in DFCO is too much and some throttle is needed to maintain speed. I've done the neutral coast a couple times.
    On the safety side, it is really no different. The brakes are still there at full assist. This is not about manually turning the engine Off, which is a thing for some folks also.
    Regardless on an MT, the engine should not die when coasting in neutral.
  7. Sep 21, 2021 at 9:51 AM
    eon_blue
    Azusa, CA
    yeah I agree the engine should not die, that is weird...I don't know about all the new tech in the newer trucks but that can't be normal.
    Technically if you're taking a driving test they'll fail you for coasting in neutral but I know we're all well past needing to take a drivers test lol. I just can't imagine doing that and having to ride the brakes more often for the most part.
    Turning the engine off while coasting....if someone did that with me riding in the vehicle I'd commandeer it from them, wtf
    Skydvrr likes this.
  8. Sep 21, 2021 at 9:55 AM
    Toyko Joe
    Toyko Joe Here for the pictures
    Does the engine die and all the warnings come up as if you ‘stalled’ or does the engine shut off and all accessories still functioning?
    Is this push to start ignition or keyed?
    Strange, it kind of makes sense if the truck had an auto-off function like other manufacturers so they can get the added fuel economy of not running at a stop light but how would that work with a Manual transmission?
  9. Sep 21, 2021 at 9:58 AM
    wrightme43
    wrightme43 Well-Known Member
    Scottsville Kentucky
    17 Double Cab M/T TRD Offroad Blazing Blue Pearl
    Redline custom leather shift and e-brake boot. VFTUNE Super Full Otto cycle, octane learning, premium fuel.
    2017 M/T long down hill on drive home, do it almost every day. No shut off, no problem. If my torque converter blows up on my manual transmission truck, well I just wasn't meant to have one, and I will carry on without it.
  10. Sep 21, 2021 at 9:59 AM
    Toyko Joe
    :rofl:
    MalinoisDad, trazerr and tonered like this.
  11. Sep 21, 2021 at 10:00 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That is the truth. I have always been a fan of 10yr retests. Maybe less for motorcycles. And, I kinda miss annual vehicle inspections from growing up in PA. Of course, there are negatives with that, but . . .
    I've only done this a few times out of curiosity. It is only at a point where no brakes are required.
    That said, the way that most every AT is operated, folk do ride the brakes for extended periods. I typically shift ATs, so there's that.
    It used to be called Polish Overdrive. Might have tried it in my youth, but yeah, not quite good operation.
    All 3rd Gen MTs have old school keys.
    shakerhood and eon_blue[QUOTED] like this.
  12. Sep 21, 2021 at 10:01 AM
    bijick
    bijick such mods much want
    E
    Stl
    2013 MGM Singular Cabular Selectable
    OME 884’s ,Dakar hd’s, Jba uca, lce header, 4.88’s, Arb locker , j shift tcase-T4R, arb bumper, leer topper, 3500w inverter, mad wife, scratched paint, skid plates, snorkelerer, led flush mount reverse lights, etc..
    Lol the fuel shuts off in gear because the wheels are turning the engine.
  13. Sep 21, 2021 at 10:03 AM
    eon_blue
    Azusa, CA
    Your torque converter is your clutch, which I guess you could blow up and that also wouldn't be pretty. Somewhere on here there's a build thread with photos of a guy with a turbo first gen that blew up his flywheel under boost and it almost tore through the bottom of the cab. Destroyed the bell housing of the trans. He was pushing crazy PSI on the stock clutch though.
  14. Sep 21, 2021 at 10:09 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Welp, I tried.
    Anton338, Hobbs and Beerpayzdabillz like this.
  15. Sep 21, 2021 at 10:11 AM
    #35
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    OP, I would call Toyota customer service and open a case with them. If they don't respond as expected, I would also open a case with the NTHSA. I don't have to tell you but pretty dangerous when the engine just quits at a high rate of speed. FWIW, my 18 MT has never done that.
    tonered likes this.
  16. Sep 21, 2021 at 10:11 AM
    #36
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Technically illegal in some areas because it burns your brakes. Keep it in gear, man.
  17. Sep 21, 2021 at 10:12 AM
    #37
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    This thread turned into a dumpster fire.
    I've owned plenty of manual cars, sometimes people just don't want to downshift. Who cares! Some could even make the argument that someone may prefer to use the brakes rather then wearing out the clutch with constant downshifts.
    G8R_Taco, Anton338, grogie and 3 others like this.
  18. Sep 21, 2021 at 10:13 AM
    #38
    fourfourone
    Tell me one place where its illegal to coast in gear with a manual transmission.
    rtzx9r, Anton338 and wrightme43 like this.
  19. Sep 21, 2021 at 10:16 AM
    #39
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It was (maybe still is) illegal to perform oral sex in PA?
    It's illegal to drink in Bourbon County.
    I mean, this could get fun.
  20. Sep 21, 2021 at 10:17 AM
    #40
    fourfourone
    What....
