Engine shuts down when warm
Discussion in '1st Gen. Tacomas (1995-2004)' started by trentbird, Jan 20, 2015.
  1. Jan 20, 2015 at 9:28 AM
    trentbird
    trentbird [OP] New Member
    Houston
    1999 tacoma SR5
    I have a 1999 Tacoma 4 cyl. and it has been shutting down after it warms up to normal operating temp. It won't restart until it has cooled down a bit.
    I have replaced just about everything related to the problem (fuel pump, spark plugs and wires, EGR valve, Pressure regulator, and also took apart the throttle body and cleaned that as well.
    Any suggestions on what to do next?
  2. Jan 20, 2015 at 2:26 PM
    jmich2001
    jmich2001 Well-Known Member
    Toms River, NJ
    12 Access Cab TRD OR
    Yellow Fog Lamps, Ham Radio
    Timing? Valves? Vacuum leak?
  3. Jan 20, 2015 at 6:57 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    have you looked under the truck to see if the cat is clogged and glowing red? it will become more restricted when it gets hot and it may be choking the engine.
    feel the exhaust pipe air flow when cold and keep feeling it as it warms up to see if you feel the exhaust flow slowing down.
    the other thought is your coil is cutting out when it gets hot, to test this, have a "known to be good" spare plug handy and check for spark when it dies
  4. Jan 20, 2015 at 11:46 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    Is the check engine light (CEL) on?
    When it stops running you need to determine if it's still sparking when you crank it. If it's still sparking, then you've narrowed it down to a fuel problem. If it's not sparking, then try to figure out if it's the ignition system itself, or a sensor not giving the computer the correct info. I'm thinking the camshaft or crankshaft position sensor since these can exhibit these symptoms, shorting out when hot, but working once they cool off. Although, I'm not sure if these would throw the CEL always if bad.
  5. Jan 20, 2015 at 11:50 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Coil sounds like a good idea. I had that problem on a vw bug once and it drove me crazy. Thought something was seriously messed up. Turned out to be just the coil. Only happened after it was warmed up.
  6. Jan 25, 2015 at 5:06 PM
    Darl Bundren
    Darl Bundren New Member
    WNC
    Stock 2WD
    You might take a look at your EFI relay and wiring. My '91 Land Cruiser would stall out when the engine got warm until I redid the wiring. Not the same vehicle, no, but the symptoms sound similar. Good luck with the hunt!
  7. Aug 15, 2015 at 9:17 AM
    prodelivery
    prodelivery Well-Known Member
    Tay
    '98 reg cab 4wd 5 speed GREEN
    Coolant temperature sending unit. I had the same problem.
