Engine shuts off at high RPM
Discussion in '1st Gen. Tacomas (1995-2004)' started by imnotevenfromhere, Jan 16, 2023.
  1. Jan 16, 2023 at 5:24 PM
    imnotevenfromhere
    imnotevenfromhere [OP] New Member
    Hi everyone, posting here to see if anyone has a general idea as you were all very helpful in my first post(not related). When I rev it in park the truck will shut off when the needle comes back to idle RPMs. It won’t do this while driving. It also won’t shut off if I keep the pedal pressed and keep it above idle RPMs while parked. I’ve recently installed a new muffler, spark plugs, battery, alternator, and fuel filter. This happened well before any replacements. Thank you.
  2. Jan 16, 2023 at 5:33 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Possible idle air control valve issue.
  3. Jan 16, 2023 at 5:36 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    How up to date are you on maintenance? MAF, throttle body clean?
  4. Jan 16, 2023 at 6:21 PM
    imnotevenfromhere
    I’ll give cleaning the throttle body and MAF a shot this weekend. If this doesn’t help I’ll have a look at the idle air control valve. Thanks guys, I’ll post update afterwards.
  5. Jan 17, 2023 at 9:23 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Could be TPS, or a vacuum leak as well. Have you replaced or inspected the vacuum lines? Outside of a visual inspection, you can smoke test, or spray an EFI safe cleaner (not brake cleaner, burning brake cleaner will kill you) around the various hoses and see if the engine idle changes. If you have a propane torch, you can also use that (unlit, obviously).
