Engine shuttering
Discussion in '1st Gen. Tacomas (1995-2004)' started by RangeDrive, Sep 24, 2017.
  1. Sep 24, 2017 at 9:49 AM
    RangeDrive
    RangeDrive [OP] Well-Known Member
    02 V6 Double cab
    Icon front end, OME Dakar rear, ARB front bar
    I was driving my V6 Tacoma on the highway when all of a sudden the engine started vibrating . I know it's the engine because it vibrates at idle and at all speeds. This happened out of the blue, and wasn't gradual. The engine has 315,000 miles and has no check engine lights. Any thoughts ? Head gasket? I don't think it's a misfire because there is no check engine light.
  2. Sep 24, 2017 at 9:56 AM
    Glamisman
    Glamisman Well-Known Member
    there has to be a ceertain number of misfires before the CEL is illuminated... just wait.
  3. Sep 24, 2017 at 10:33 AM
    twblanset
    twblanset Well-Known Member
    Todd
    Vacaville, CA
    2015 TRD OR
    Mild lift and some tasty bits
    Does it feel less powerful? Check your motor mounts and your tranny mount.
  4. Sep 24, 2017 at 10:39 AM
    RangeDrive
    02 V6 Double cab
    I feel like it's misfiring, a motor mount or tranny mount wouldn't just start out of the blue, it would be gradual, like a carrier bearing
  5. Sep 24, 2017 at 12:46 PM
    twblanset
    Todd
    Vacaville, CA
    2015 TRD OR
    Check your coil packs. Unplug one at a time. If you unplug one and the engine doesn't start missing worse, then you found it.
    Dalandser likes this.
  6. Sep 24, 2017 at 10:53 PM
    RangeDrive
    02 V6 Double cab
    Solved: It was a bad spark plug wire.
  7. Sep 24, 2017 at 11:28 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    coil pack is what it sounds like
  8. Sep 24, 2017 at 11:45 PM
    RangeDrive
    02 V6 Double cab
    Well it was the wire running from the coil pack to the other cylinder, it had apparently blown and was ground/arcing to the engine
