Engine shutting down while off road
Discussion in '3rd Gen. Tacomas (2016-2023)' started by blacktaco77, Jul 14, 2024.
  1. Jul 14, 2024 at 9:05 AM
    blacktaco77
    blacktaco77 [OP] Well-Known Member
    Noah
    21 TRD off road black 4x4
    Hello tw. I have heard about a problem with the 3rd gen’s being starved for oil on steeper inclines and off camber situations, which I have got the dash notifications for a few different times.. but has anyone had the Low engine oil pressure notification and had your truck shutoff? This is the 2nd time this is has happened to me and wasn’t on a crazy angle or anything. Is this normal? Also how is this prevented in the future so I don’t go rolling down a hill. I posted a vid of this one time for context https://youtube.com/shorts/IlhhYK_u4wE?si=GttzWpWzZIivieCq
  2. Jul 14, 2024 at 9:14 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    :eek:That is definitely not normal, and is a concerning safety issue if encountered on a highway or steep hill. Not criticizing you, but why would anyone even ask if something like it was “normal”? I would go to a reputable dealer before driving it much again and have them check it plus they should get the codes. Hopefully it’s drivetrain related and you are still under warranty. It may just be something like the fuel pump going, which might be under a recall, and hopefully it’s not too major.
    Pwakchop likes this.
  3. Jul 14, 2024 at 9:26 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    It's hard to tell through that aftermarket exhaust, but that does not sound like a happy engine.
    Pull the codes. And what's your oil level when it's level?
    RIX TUX, ppat4 and blacktaco77[OP] like this.
  4. Jul 14, 2024 at 9:38 AM
    blacktaco77
    Noah
    What I meant by that question is, does this happen to 3rd gen’s when you are off roading and pushing the truck to its limits. This doesn’t happen when I am driving under normal conditions. I had took a pretty hard skid plate hit about 20 seconds ago as well but no visual damage to the undercarriage. Both times this has happened have been from off road use.
  5. Jul 14, 2024 at 9:39 AM
    blacktaco77
    Noah
    Will do that right now just got home from the trip. It definitely didn’t sound happy when I started it again but that unhappy idle went away after about 10-15 seconds.
  6. Jul 14, 2024 at 9:44 AM
    2023tacomer
    2023tacomer Well-Known Member
    Not normal, and that is not really pushing or using the truck harder than toyota intended. If you were driving through that at speed, I'd agree.
    Hopefully you are in 4 lo trying to crawl around out there. Also, is the truck a manual and did you just stall it?
  7. Jul 14, 2024 at 9:45 AM
    blacktaco77
    Noah
    Truck is automatic and was in 4lo
  8. Jul 14, 2024 at 9:45 AM
    2023tacomer
    Wait, after the incident you didn't check the oil level? And you also drove home without checking? This is why I don't buy used vehicles. Why???
  9. Jul 14, 2024 at 9:49 AM
    blacktaco77
    Noah
    I just got an oil change and checked all my fluids before the trip it was fine.
  10. Jul 14, 2024 at 9:53 AM
    blacktaco77
    Noah
    Oil level is at the max fill line
  11. Jul 14, 2024 at 9:54 AM
    2023tacomer
    Yea, and you had the oil light come on and the truck shut down on you. With a then hard restart, and rough running for 15 seconds. You also stated you bashed the undercarriage. An oil change yesterday doesn't mean crap. Weird reasoning on your part. Good luck and hope it's really ok
    D1RTYH0B0 likes this.
  12. Jul 14, 2024 at 10:32 AM
    STEELeR43
    STEELeR43 Well-Known Member
    Hawaii
    2023 Tacoma TRD 4x4 6MT
    3" Icon Lift, SPC UCA, B&M Sport Shifter, OTT Tune
    You mentioned not crazy angle, but video showing you climbing rocks. Also, your video, sounds like your truck engine flooded out with fuel, after it stalled. Like somebody else somewhat said, I would drop skid plate, and check out engine oil pan, if smashed.
  13. Jul 14, 2024 at 10:34 AM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    I had all the aforementioned warning lights and the low oil engine pressure light AND my motor shut off, once. That was about a year ago. Rolling backwards in drive on a trail at a slight incline. I turned the ignition off then on again and there were no further issues.
    blacktaco77[OP] likes this.
  14. Jul 14, 2024 at 10:47 AM
    blacktaco77
    Noah
    You were rolling backwards in neutral when it shut off?
    Road_Warrior[QUOTED] likes this.
  15. Jul 14, 2024 at 10:51 AM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Correct. Rolling backwards, it stalled and the engine shut off. I have an automatic trans if that helps at all.
    It seems to be a somewhat common occurrence when it happens in that order. I read about it a fair bit around TW after it happened to me.
  16. Jul 14, 2024 at 12:43 PM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    I've done that once too, backing a trailer up my drive, it rolled forward 15 feet while still in reverse.
    Truck shut down, the screen lit up and called me a dumbass. However, it started right up again and didn't sound like it was chewing gravel when doing so.
  17. Jul 14, 2024 at 12:50 PM
    OnHartung'sRoad
    You can’t roll it backwards in D or lower gears, or N on an off-road AT, the hill assist control makes terrible noises and will lock it up when trying to roll it backwards.
    I personally hate that system as it’s dangerous to put it in reverse on a hill to back up because you only have brakes holding you up then. I always used to keep my 1st Gen in D or lower gears when rolling a bit back to get another running start to get over a rough section or step.
    blacktaco77[OP] and Pwakchop like this.
  18. Jul 14, 2024 at 1:06 PM
    Pwakchop
    Pwakchop Well-Known Member
    Nate
    Georgia
    2021 Cement DCSB TRD Sport
    Whole lotta' momentum
    Interested to see what it is, I do some rather heavy off roading and my truck is a 2wd ( :eek: , I know) so I do roll back quite often while in drive to get some momentum. I agree that rolling back on a hill while in drive is just the best option at times. Will see, I haven't had anything like this happen to me though.
  19. Jul 14, 2024 at 1:10 PM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Yep sounds about right lol, I was terrified it was locked up and I was stuck in the middle of nowhere but it worked just fine afterwards.
  20. Jul 14, 2024 at 3:03 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    My AT truck has rolled back in gear and caused it to stall
    Road_Warrior likes this.
