engine sludge+scratching ticking noise
Discussion in 'Technical Chat' started by timbo805, Jul 2, 2011.
  1. Jul 2, 2011 at 10:46 PM
    timbo805
    timbo805 [OP] Well-Known Member
    SanDiego
    09 tacoma trd sport pre-runner
    Hey TW i havent done a oil change in my truck in about 4-5 months , bought myself mobil 1 but haven't had enough time to service my truck , so about 2 days ago i started hearing weird noises from my engine while i decelerate it almost sounds like a scratching/knocking noise, so today i noticed i was getting a very strong knock and scrach wile turning my car on and also while waiting out in the sun my ac wasnt cooling and my motor temp was going way up than normal, i got home changed the oil and only about 1 qrt of used oil came out and it was black black black the oil cap and neck had masive amounts of black sludge in it, my oil filter was literally dry, changed the oil put mobil 1 in new filter turned my truck on same scratch and knock any suggestions ?
  2. Jul 2, 2011 at 10:50 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    I heard Mobil 1 isn't a real full synthetic anymore, Run Castrol Edge through it.
  3. Jul 2, 2011 at 10:55 PM
    timbo805
    SanDiego
    i did put in 5.5 qrts of castrol i belive new filter too
  4. Jul 2, 2011 at 10:56 PM
    timbo805
    SanDiego
    this would be my first time running mobil 1 it started making the noise before the oil change .... puziling
  5. Jul 2, 2011 at 10:56 PM
    krimson
    krimson Nothin
    TRD Off Road
    Stick with Gastrol man, you don't want keep on switching different types of oils through your engine.
  6. Jul 2, 2011 at 10:58 PM
    timbo805
    SanDiego
    that's exactly what i was thinking i know there's something terribly wrong if it burnt trough 4 quarts in 5 months
  7. Jul 2, 2011 at 10:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Engine making noise, oil filter dry, and only 1 quart of oil comming out of pan......Engine could very well be toasted due to oil starvation.,
  8. Jul 2, 2011 at 10:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yup.
  9. Jul 2, 2011 at 11:00 PM
    krimson
    krimson Nothin
    TRD Off Road
    I was told if you plan on switching to synthetic you keep running synthetic through that engines life. What I ment was types of oil not brands..
  10. Jul 2, 2011 at 11:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You can switch from Dyno oil, to synthetic as many times as you want. No harm will be done to the engine.
  11. Jul 2, 2011 at 11:02 PM
    krimson
    krimson Nothin
    TRD Off Road
    Ah ok, I just remembered my friend telling me that when I was at his shop. Because I was planning on running synthetic through my engine.
  12. Jul 2, 2011 at 11:10 PM
    timbo805
    SanDiego
    thats the thing no check engine lights no oil light my coolant is fine ... im just lost
  13. Jul 2, 2011 at 11:11 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    Will oil go bad if you let it sit for a long period of time? One of my dad's cars hasnt had an oil chang in about a year, but only because it never gets driven, so it just sits. It has Mobil 1 synthetic in it...
  14. Jul 2, 2011 at 11:15 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    Thanks, I guess ill have to go over next weekend and change the oil for him.
  15. Jul 2, 2011 at 11:18 PM
    timbo805
    SanDiego
    yes they do everything seems normal exept noise
  16. Jul 4, 2011 at 6:21 PM
    Visegripmech
    Visegripmech Member
    Riverside, CA
    04 Prerunner TRD
    Basically the same thing happened to me. After driving a leaky old volkswagen for 20 years, I foolishly neglected to regularily check the oil in my new 2004 PreRunner (seven years ago it was new, when I bought it I mean) This compounded with these three factors
    1. I live approximately 1000 feet from my shop. On any typical day I may take 10 trips to and from home, the bank, grocery store, etc, all of which are less than 5 miles. The truck has a mere 69,000 miles on it now.
    2. The last oil change, done waaaaaaay too long ago (almost 10,000 miles) was done by the dealer - and the oil filter was slowly leaking un-noticed onto the skid plate ever since.
    3. Never bothered to service or inspect PCV system.
    Yeah I know - WHAT AN IDIOT. Turns out that this is the perfect recipe for a sludged, if not totally destroyed engine. Since I'd never heard or saw anything unusual, (It had just passed CA Emissions a month earlier) it was only dumb luck that I decided to check the oil before taking a 60 mile drive one day. The dipstick had crap stuck to it and it took 3 1/2 quarts to top off! I felt like I had an enormous "DUMBASS" sign over my head - which is still there, its just not all lit up like it was at first.
    Since then every morning starts with a big puff of smoke (at the time it was winter and I took it for condensation), I'm 99% sure the valve seals are toast. As far as all the other terrible damage that certainly occurred - I've decided to pretend it's not there. :anonymous:
    4000 miles later it still runs great - there are some creepy noises (that may have been there all along) but I'm not planning on selling it or towing any bulldozers up a mountain.
    Don't cry for me, I'm already dead
    But let this be a warning to anyone with what I call the
    "MY BRAND NEW TRUCK COULDN'T POSSIBLY NEED ANY ATTENTION" syndrome
    CHECK YOUR OIL REGULARILY!
    IT'S EASY! DO IT NOW!
  17. Jul 4, 2011 at 8:01 PM
    timbo805
    SanDiego
    couldn't have said it better man !
  18. Jul 4, 2011 at 8:16 PM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    i run mobil1 i have in all of my cars and trucks never had any problems concerning the engine at all. i do not attribute that to the brand of oil in any way but, quite possibly the choice to run a quality synthetic oil could very well make a difference in the long haul.
    i don't follow what oil company's do with their products so what your saying you heard is that mobil1 is not a full synthetic any more? i thought mobil1 was the first full synthetic oil thats it's claim to fame. that and the racing heritage and being endorsed by a lot of factory's for their new cars.
    lets just say dam the cost what is the best oil to run through your engine facts not opinion. because hearing mobil1 may not be what i thought it to be is a bit confusing. i know this is a topic that has been beaten with a stick, but concrete facts would help.
  19. Jul 4, 2011 at 8:53 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    sooo... if that was the case wouldn't engine and gear oil in the stores have a expiration date on it? :confused:
    OP...how long had it been since you checked the oil level on the dip stick? :eek:
  20. Jul 4, 2011 at 9:21 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Yep. If I'm not mistaken, it's the additives are what break down in the oil.
