engine sludge+scratching ticking noise
Discussion in 'Technical Chat' started by timbo805, Jul 2, 2011.
  1. Jul 4, 2011 at 9:48 PM
    timbo805
    timbo805 [OP] Well-Known Member
    SanDiego
    09 tacoma trd sport pre-runner
    Dropped my truck off at the mechanic today 2-4 days FML !!!!
  2. Jul 4, 2011 at 10:14 PM
    BlazeTaco
    BlazeTaco Well-Known Member
    PA
    4.0l 6sp SR5
    TRD Exhaust TRD Filter
    I would have to say your engine is toast. knocking is usally a sign that you have rod bearing damage. only one quart is not near enough oil and a dry oil filter means your engine wasnt pumping any oil to the bearings or other parts of the engine. Changing the oil wont fix the bearing damage.
  3. Jul 4, 2011 at 10:28 PM
    timbo805
    SanDiego
    waaaaa waaaa waaa wawawawawawawawawawawawawawa..... your probably right lets see what happens.
  4. Jul 5, 2011 at 11:06 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I wonder why the manufacturer's aren't held responsible for putting an expiration date on the box's and bottles? Most consumers haven't got a clue as to how old the oil is sitting on shelf's in stores and in their garage.
  5. Jul 6, 2011 at 10:20 PM
    timbo805
    SanDiego
    the verdict..... need new motor FML !!!!!
  6. Jul 6, 2011 at 10:25 PM
    timbo805
    SanDiego
    wat doasnt kill you makes you better man... so if i read right i cant have a 2005 motor and up ???
  7. Jul 6, 2011 at 10:27 PM
    timbo805
    SanDiego
    also if any body in the socal area finds a good deal on a motor please let me know i would appreciate it thanks
  8. Jul 6, 2011 at 10:28 PM
    timbo805
    SanDiego
    yes !!!! my tacoma is a mexican tacoma so that means i can put a + 05 motor in ?
  9. Jul 6, 2011 at 10:57 PM
    Who Dat Popcorn
    Who Dat Popcorn Dafuq
    Ricky
    Richmond, VA
    Sold :/
    SOLD
    Sorry to hear about the situation.
    Not to be a douche or anything, but I thought things like oil were common sense. It just goes to show that a small mistake can cost you a fortune. :sorry:
  10. Jul 6, 2011 at 11:23 PM
    timbo805
    SanDiego
    its common sence man but when you have a new truck you think to youre self whats 4-5 months without a oil change when i have always maintained it properly ... just a bump on the road man learn from other peoples mistakes
  11. Jul 7, 2011 at 7:16 AM
    tacobox
    tacobox Evasive Maneuvers PMKMS
    Sorry to hear. You could use a 2005 & up engine. All you'd be using is the long block. All the other parts, sensors and emissions BS would be transfered over.
    Extended warranty ftw
  12. Jul 7, 2011 at 8:30 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Its good to be old fart that distrust everybody including himself :D
    I check all the bolts, oil levels for a month after I do the change. I always have a feeling that I screwed up something so I keep rechecking things
    I think its called OCD :eek:
  13. Jul 7, 2011 at 6:53 PM
    timbo805
    SanDiego
    right on man, i will learn something from you and try to do the same, at least check my fluids more often haha.
  14. Jul 7, 2011 at 6:54 PM
    timbo805
    SanDiego
    also i found a motor 2007, 700 bucks and i dont have to give up my old one! is that a good deal or what im going with my mechanic to check it out tomorrow in the states.
  15. Jul 7, 2011 at 8:49 PM
    #35
    timbo805
    SanDiego
