Engine smoke after coolant flush
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rclarkson, Jun 17, 2024.
  1. Jun 17, 2024 at 2:20 PM
    Rclarkson
    Rclarkson [OP] Active Member
    2008 Single cab 2.7l
    Hey all, so I’m a beginning but felt a coolant flush is something I can handle. I drained just the radiator, not the engine block ( I forgot). But after that I poured 1 gallon of distilled water in the radiator ran it for a bit, flushed that then added 1 gallon of antifreeze 50/50 and after burping the hoses for a while it seemed no more would go in so I drove it to come back to find it was no longer filled to the top of the radiator. So I’m adding another gallon and it’s going very slowly. I started the engine and within a minute smoke was coming from under the intake manifold, so it seemed. Did I do something wrong? Is it fixable? Did I ruin the engine?
  2. Jun 17, 2024 at 3:00 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    Are you sure it's smoke? It could be that you just spilled some coolant when filling or draining on the engine and it just got steamed off when the engine got warm. If your coolant and your oil isn't looking like a milk shake, and you didn't overheat the engine it's hard to imagine you did any permanent damage.
    Rclarkson[OP] likes this.
  3. Jun 17, 2024 at 3:01 PM
    kidthatsirish
    Also with it being a 2008, and you are doing coolant maintenance, go ahead and check to make sure you have a stainless steel coolant line going under your intake manifold.
  4. Jun 17, 2024 at 3:38 PM
    Rclarkson
    I did spill some coolant but it didn’t appear at the time to reach the back of the engine where it appeared to be smoking. I shut it off immediately. I should state, when I thought I was finished, I only added 1 gallon of coolant before driving it about 25 miles, then came back to see the fluid wasn’t filled to the top. Now as I add more it seems again it won’t take anymore than a 1/10 of a bottle. Burping is going ridiculously slow.
  5. Jun 17, 2024 at 3:41 PM
    Rclarkson
    I also didn’t have the engine running long enough for it to heat up. Less than a minute
  6. Jun 17, 2024 at 3:52 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It's 100% normal to need to top off the fluid while refilling the system.
    I leave the radiator cap off, and let the truck run until the thermostat opens.
    Once it opens, the coolant will go down. Add more coolant. Let it run a couple more minutes. If the coolant doesn't drop anymore, put the cap back on and drive it.
    Come back, let truck cool down check the coolant in the radiator. If it's low, top it off. And 99% of the time that's good enough. As long as you have plenty of coolant in the over flow, it will be fine.
    Now to really throw you for loop. And to add unmercenary information to this rambling post, I now use a vacuum filler.
    It's "faster" and you'll know if you have a leak in the system at the same time.....
    Your avg. at home DIY guy doesn't need a vacuum filler for a Tacoma. They don't air lock like a Nissan will.....That's why I have one. A damn Nissan.
    GilbertOz and Torspd like this.
  7. Jun 17, 2024 at 3:54 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Coolant tube at the back of the engine. Is yours plastic and leaking?
  8. Jun 17, 2024 at 4:11 PM
    Rclarkson
    Do I HAVE to take the intake manifold off to see?
  9. Jun 17, 2024 at 4:20 PM
    TnShooter
    Deogee
    STOCK
    Do you have to? No.
    Will it require metamorphosing into a contortionist? Yes.
    In short, Find the starter. Then look above it.
    Good luck.
    Torspd likes this.
