engine sound rough when driving straight ,and quiet when turning
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pancake, Sep 3, 2011.
  1. Sep 3, 2011 at 2:48 PM
    pancake
    pancake [OP] New Member
    jose
    houston texas
    07 Pre Runner SR5, 6 inch pro comp lift
    6" lift ,285/65/17 Duellers
    Hello, Im brand new to this site,well, 1st time posting,I have an 07 prerunner SR5 with 6 in pro comp lift and sum 285/60/17 bridgestone duellers,K&N filter,and just recently,I started noticing a louder humming noise from the engine all the time,and no noise when Im making a turn,took it to a parking lot and just cruised in circles and heard no noise ,it only sounds louds when Im going strait,tires are good ,air is good,,
    any suggestions??
  2. Sep 3, 2011 at 2:52 PM
    98tacoma27
    Ben
    Not Beech Creek
    Turning and non-turning shouldn't affect the engine sound or hum. It sounds more like a wheel bearing.
  3. Sep 3, 2011 at 3:27 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Engine/trans mount?
  4. Sep 14, 2011 at 7:32 PM
    Heckler2008
    Heckler2008 Member
    I have the same thing, it's not the motor, sounds like tire hum but goes quite when turning. I was guessing wheel bearings also. Thought maybe it was alinement but just got that corrected and didn't go away.
  5. Sep 21, 2011 at 5:07 PM
    Heckler2008
    Heckler2008 Member
    Confirmed, replaced hub plates and wheel bearings no more hum.
  6. Oct 17, 2011 at 1:42 PM
    wfbont007
    wfbont007 Well-Known Member
    Southern NJ
    06 DC
    Same problem. Hum when straight, quiet around curves. Having bearing replaced.
  7. Oct 17, 2011 at 1:53 PM
    raswank
    raswank Well-Known Member
    Rick
    Auburn,Ma
    2010 Tacoma Double Cab 4x4 6 speed
    Grillcraft, Rear leaf TSB, 5100's at .85, with Eibachs, 265/70/17 BF Goodrich AT/S Tires, Hella 500's behind Grill, Kenwood KDC X995 H/U all Boston Acoustic speakers, JL Audio subs, Kenwood XR5 S amp, ATX Chrome 17x8 wheels
    I have this on my 2010 with 15,000 miles. It will be warrantied correct? With or without lift?
