Engine sounds like a banshee with open throttle. Possible bad pulley?
Discussion in '1st Gen. Tacomas (1995-2004)' started by darth_bronchioles, Nov 19, 2022.
  1. Nov 19, 2022 at 10:35 PM
    darth_bronchioles
    darth_bronchioles [OP] Well-Known Member
    California Central Coast
    1999 Supercharged Tacoma 4x4 Limited
    TRD Supercharger URD 7th injector kit K&N intake 4Runner Mirrors Fog Light Mod
    Whenever I open up the throttle, there is a high pitched squealing sound coming from the engine compartment. My best guess is a bad pulley or belt. It sounds like it could be coming from inside the engine block itself, but I'm not sure. I've lubed up all the pulleys I can reach to try and see if I could make the sound go away to figure out which one is bad, but that didn't do anything. The sound is also there at idle on a cold start, but goes away when the engine warms up a bit until I open the throttle. Sometimes it will go away at highway speeds, but not for long.
    Here's a video: https://youtu.be/kwISVagqgvI
  2. Nov 19, 2022 at 10:49 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    not inside. could be anything in front though incl. alternator.
    edit: it really does sound like the alt. to me. Take off belt (s) and spin things by hand. Everything should be smooth like a skateboard wheel. Nothing should be rough feeling. If nothing sticks out have an alt. shop or the auto. parts store spin up the alternator. You can also take fan off and run engine to cut out noise/eliminate/give more room and a margin of safety to look in there closer.
  3. Nov 21, 2022 at 6:17 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I am curious just how did you lube up the sealed bearings in the pulleys??
  4. Nov 21, 2022 at 6:25 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    I had that noise once (similar anyway) it was the idler pulley.
    cruxofthebisquit and Bivouac like this.
