Engine sounds like prop propeller engine
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TrueUnderdog, Nov 15, 2023.
  1. Nov 15, 2023 at 12:38 PM
    TrueUnderdog
    TrueUnderdog [OP] Member
    Brandon
    2012 Silver Tacoma TRD
    Howdy. I’m annoyingly back to ask a question I should probably direct to my local mechanic. My 2011 Tacoma has been running fine, never had an issue. Suddenly upon cranking this morning the engine sounded almost like a growl. I promptly turned it off and checked the oil. Oil was a little low so I topped it off, yet the issue persists. Can anyone make out or diagnose what happened? No check engine or oil pressure light on my dash. Link below to video of sound.
    https://youtube.com/shorts/TlnDaxwSuwc?si=ON8u6frRA4gk8Szz
  2. Nov 15, 2023 at 12:47 PM
    rmorse
    rmorse Well-Known Member
    Bobby
    Bowie, MD
    2015 Blue Ribbon Metallic Access Cab TRD Sport
    Check your exhaust
  3. Nov 15, 2023 at 12:49 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Somebody get your convertor
  4. Nov 15, 2023 at 12:53 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
  5. Nov 15, 2023 at 1:12 PM
    TrueUnderdog
    Brandon
  6. Nov 15, 2023 at 1:22 PM
    spitdog
    Sorry that happen to you.
