Engine spray
Discussion in 'Detailing' started by sirsaechao, Mar 19, 2010.
  1. Mar 19, 2010 at 12:06 PM
    sirsaechao
    sirsaechao [OP] Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    My engine is spotless but not shiny/glossy/new looking...what should I use to get the new car shiny look under the engine? Thanks.
  2. Mar 19, 2010 at 12:08 PM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    Simple green and a hose. Hose it down, simple green the F out of it. Avoid wiring if possible, let it dry up a bit with the simple green on it, hose down to rinse.. enjoy, close thread ;)
  3. Mar 19, 2010 at 12:10 PM
    jefferson
    Sex Panther
    05 PreRunner SR5
    yah, probably just road grime from rain..
  4. Mar 19, 2010 at 12:10 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    Carb Cleaner or WD40 :notsure:
  5. Mar 19, 2010 at 12:11 PM
    sirsaechao
    Tim
    Commifornia
    Yeah the hoses to look shiny and it's already clean. Just want it to look shiny.
  6. Mar 19, 2010 at 12:12 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    Armor All...just spray that stuff every where and wipe it off :cool:
  7. Mar 19, 2010 at 12:13 PM
    sirsaechao
    Tim
    Commifornia
    So just keep it away from metal so it doesn't burn when the engine gets hot? I don't want it smoking...
  8. Mar 19, 2010 at 12:25 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    ... One time I was cleaning my engine with a hose (not on my Taco. An older car with exposed plug wires) and knocked a few of my sparkplug wires loose. It was hilarious when I was trying to climb a hill on one cylinder at 12 mph floored. Engine looked SCCHWEEEET though. :D
  9. Mar 20, 2010 at 7:51 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Debadged, GC Mesh Grill, Yellow Fogs, Color Matched Headlights w/ Retros, Diff Breather Mod; mickey thompson classic IIs, 5100s, toytec springs, Dakar Leaf pack, ss brake lines, Lots more...just check the build page.
    To give a nice gloss to the engine, you can use a product like CD2, Trim Restorer from Poorboys, Black Wow, or even 303 Aerospace Protectant. CD2 is an aerosol. The rest you would apply w/ an applicator pad.
  10. Mar 20, 2010 at 10:07 AM
    soilsample
    soilsample Well-Known Member
    Donald
    Southwest Louisiana
    '09 4x4 Double Cab
    Cd2 is GREAT product.
    I use it under hood and under fender wells. It stays glossy, repels dust, helps with next clean.
    I get it at Autozone
  11. Mar 20, 2010 at 10:52 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Another +1 for CD2. If used correctly it works great and you can get it OTC at alot of automotive stores.
  12. Mar 20, 2010 at 5:58 PM
    wmb67
    wmb67 Well-Known Member
    Boston
    09 Dbl Cab Off Road Mag Gray
    +1 for the CD-2. I clean and rinse engine bay, blow dry with leaf blower, then spray CD-2 over the whole engine bay.
    Start and run truck for ~ 10 minutes, then wipe off excess. Looks great and is durable.
  13. Mar 20, 2010 at 6:05 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    WD40 would be the worst idea ever, i use it on my throttle on my bike and within like a hour where ever i over sprayed it is solid brown from the dust
