Engine stalls on first start
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlackZeppelin, Apr 4, 2022.
  1. Apr 4, 2022 at 1:10 AM
    BlackZeppelin
    BlackZeppelin [OP] Member
    Trenton
    2009 2.7 RWD Access Cab Manual
    2009 2.7 rwd manual, most of the time I start it after its been sitting for a few hours, it'll start for a second, then stall, then it starts perfectly fine on the second start.
    I'm just wondering what the issue that's causing this to happen could be, I used a cheap OBS scanner and the only thing it pulled up was ABS #2 was not getting enough voltage, which I can't imagine is at all connected to an engine stall.
    Thanks,
    BlackZeppelin
  2. Apr 4, 2022 at 1:12 AM
    BlackZeppelin
    Trenton
    There's also been a time or two where it's kept turning over and only started when I gave it a bit of gas, but idk if that was connected to the nearly dead battery or not; obviously I'm not someone who's very mechanically inclined aha
  3. Apr 4, 2022 at 6:31 AM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Mine does the same every once and a while. Haven’t ever worried about it. It’s done it since new and has 125,000 on it now.
    Dm93 likes this.
  4. Apr 4, 2022 at 8:24 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    could be a check valve in the fuel pump not holding pressure. Nothing to worry about if its that other than a second crank.
  5. Apr 4, 2022 at 5:40 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    My 14 v6 has done that from time to time since it was new too (stumble/stall on the first crank, 2nd crank starts right up), never has gotten any worse so I'm not concerned.
    Alexely999[QUOTED] likes this.
  6. Apr 4, 2022 at 6:18 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Clean the throttle body and check the battery
    koditten and 6 gearT444E like this.
  7. Apr 4, 2022 at 7:32 PM
    riverrat958
    riverrat958 Well-Known Member
    keith
    upstate ny
    2015 base crew cab tacoma
    camera source backup, camera seat covers,intermittent wiper arm
    my 15 2.7 will do it occasionally-60k
  8. Apr 4, 2022 at 7:40 PM
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
    Check the battery
  9. Apr 5, 2022 at 6:07 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Mine has done this a few times over the passed 12+ years I’ve owned it. But it might only happen 1 or 2 times a year.
    Starts up for about 1 second and shuts clean off.
    If you’re experiencing this on a weekly basis, I’d say you have a problem.
  10. Apr 5, 2022 at 6:22 AM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    My thought too. Easy way to check is to turn the key to on momentarily to allow the pump to prime, turn to off, then start it. If the problem goes away this could be the problem.
  11. Apr 5, 2022 at 6:39 AM
    Alealexi
    Houston, TX
    Did this happen anytime you disconnected the battery or changed it out for a new one? I know all Toyotas do this when ever you do that. It is the reason I mentioned to check the battery since OP has a low voltage code.
    koditten likes this.
  12. Apr 5, 2022 at 6:50 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Our trucks don't have a key on prime, the pump only runs when the PCM sees a start or engine speed signal.
    garciav and TnShooter like this.
  13. Apr 5, 2022 at 7:19 AM
    TnShooter
    Deogee
    STOCK
    Toyota has used the “No Prime” system since at least the 1st Gen 3.4 engine.
    And AFAIK, they still haven’t made it easy to check pressure. You have to have a special Banjo adapter for the 1st Gen and a T adapter for the 2nd Gen.
  14. Apr 5, 2022 at 7:24 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    I always turn the truck to the on position then wait a second for the relay to click. It sounds like the relay is on the right side of the dash. If I do this before I start the truck I never have a problem, so I believe the issue involves the security key and not the ignition system.
    My 2008 4cyl did not have security keys and I never had a problem starting immediately.
  15. Apr 5, 2022 at 7:32 AM
    TnShooter
    Deogee
    STOCK
    I’ve never heard a relay click in mine.
    I’ve heard the Shift Lock click.
    But that could be because of years of not wearing hearing protection while running mowers, saws and trimmers.
    NAAC3TACO[QUOTED] likes this.
  16. Apr 5, 2022 at 7:48 AM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    Maybe that’s what I’m hearing.
  17. Apr 5, 2022 at 7:55 AM
    TnShooter
    Deogee
    STOCK
    Maybe? The easiest way for me to tell the security system is off, is by looking at the light. But I have to be honest, I never really look at it. I just get in, crank it, and go. :rofl:
    I am like most people. I don’t notice things until there’s a problem. :anonymous:
  18. Apr 5, 2022 at 8:22 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    The only relays I hear click on mine are the 4wd ECU running it's self test and then the hydraulic brake booster running it's self test when it hits 5 mph.
    TnShooter likes this.
  19. Apr 5, 2022 at 8:33 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    Mine does this every time I disconnect the battery. It’s the ECU resetting or something. Not sure what would cause this if the batt wasn’t disconnected.
  20. Apr 5, 2022 at 10:34 AM
    Fullboogie
    Dave
    Houston
    Thanks for the correction. My other cars do so I made an assumption - and it was a bad one.
    LooneytuneSR5 and Otterstuff like this.
