Engine stalls when warm
Discussion in '1st Gen. Tacomas (1995-2004)' started by TubMaster, Sep 20, 2010.
  1. Sep 20, 2010 at 6:09 PM
    TubMaster
    TubMaster [OP] Member
    Bob
    High Point, NC
    97 Tacoma extended cab
    Hey, I have a 1997 Tacoma 2.4 The timing chain went at 440,000, so I replaced the engine.
    Even though my truck is standard 2 wheel drive, my son found an automatic 4 wheel drive engine and we put it in.
    It ran great for 300 miles then shut down while driving at 55 mph.
    The engine will run once it cools down, but when it gets warm, it sputters and dies. (idles at 1k when cool, then when warm drops to 500, shoots back up to 1k, then back to 500 and then dies.) If I keep the rpms around 2k it runs fine until I let it down to 1k and then it just dies. It has new plugs, wires, a new coil, rotor, cap and starter. Someone told me it could be the distributor. Any ideas?
  2. Sep 20, 2010 at 6:20 PM
    DocBrown86
    DocBrown86 Yota Doc
    Brian
    San Diego (Spring Valley)
    04 Prerunner
    toytec coil spacers, tokicko struts/dubcab springs, energy suspension rack bushings, bilstien hd shocks, K&N FIPK2, Flowmaster 50DF, ScanGuage2, 5000k HID's, horn mod, other stuff that I forgot to list
    The first thing i'd check would be the idle control valve. It may be dirty.
  3. Sep 22, 2010 at 5:36 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    How does the engine run in general?
    When it stops and then cools down, does it run as well as it did after first being started?
  4. Sep 22, 2010 at 1:50 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Temp related problems point to a faulty coolant or intake air temp sensor. It's sends a cold reading to the computer even when hot. It usually won't set a code.
  5. Sep 23, 2010 at 12:21 PM
    TubMaster
    Bob
    High Point, NC
    ok, now i am not getting spark from the plugs. checked the pick up coil, rotor, cap, prim and secondary coil, fuses and power to the coil is good. havent checked the air gap or the igt signal from the ecu because i don't know how to do that. anyone know how?
  6. Sep 23, 2010 at 1:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Are you getting any codes?
  7. Sep 23, 2010 at 1:15 PM
    TubMaster
    Bob
    High Point, NC
    dont have a tester with me, so i really dont know. i have been looking for info on how to test the igniter. i understand that to be next in line to check.
  8. Sep 23, 2010 at 2:42 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    I don't think there is an igniter is there ? Did they start again ?
    I had them on my old toyotas pre -1st gen
  9. Sep 23, 2010 at 3:26 PM
    TubMaster
    Bob
    High Point, NC
    yes there is. its mounter to the passenger side fender well behind the air intake box.
  10. Sep 23, 2010 at 3:30 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Then yeah that'd be a great place to check, those igniters on the old toys (Like I said, didn't even know they still used them haha:D)
    were always suspect & almost always the first thing to check w/voltage drop/hard starting/ no spark etc;
  11. Sep 23, 2010 at 9:03 PM
    TubMaster
    Bob
    High Point, NC
    ok, the igniter is good but still no spark any one know how to check the ecm?
  12. Sep 23, 2010 at 9:23 PM
    DocBrown86
    DocBrown86 Yota Doc
    Brian
    04 Prerunner
    Have you checked the crank sensor yet?
  13. Sep 24, 2010 at 9:57 AM
    TubMaster
    Bob
    High Point, NC
    Crankshaft position sensor is within specs.
    Anyone know how to check for IGTcoming from the engine control module?
  14. Sep 24, 2010 at 12:03 PM
    TubMaster
    Bob
    High Point, NC
    the only thing left that I know how to do is to find a replacement ecu and check that.
    any other ideas? i am really lost here...
