Engine Start up/turn over problem
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Hueston, Feb 6, 2017.
  1. Feb 6, 2017 at 4:50 PM
    Hueston
    Hueston [OP] Member
    Hueston
    2016 Grey Tacoma TRD sport
    Has anybody come across slow start up. I've notice it's taking my Tacoma longer to turn over the last couple of days. I thought maybe it was the cold weather but went to the grocery store just now, currently 55 degrees and it took about 3 seconds for my engine to turn over and start.
  2. Feb 6, 2017 at 5:34 PM
    stevebaz
    stevebaz Well-Known Member
    2016 access cab, TRD offroad 4x4, Quicksand
    Check the voltage at the battery with the engine off. For a fairly new battery it should be over 12.5 volts. Then check with the engine running it should be over 13 volts. If the volts are low with the engine running time to see the dealer before you get stuck. If you have good voltage running but bad voltage with the battery not running then you either have a battery failing or you have a voltage draw when the engine is off.
    Hueston[OP], Joe23 and boynoyce like this.
  3. Feb 6, 2017 at 5:39 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    definitely can't be the cold at 55F
    It was -40C at the cottage last weekend and she started no problem, and I forgot to plug in, that was first thing in the morning after the truck sat for probably 18 hours.
    Like @stevebaz said...either faulty battery or something is drawing power...
    if you haven't done any mods not sure what that drawing power would be.
    Unless you've done something to the truck? Using the wrong oil or something?
    dYL0n likes this.
  4. Feb 6, 2017 at 5:41 PM
    Storman
    Storman Fukitol abuser
    South Western PA
    2017 SR AC 4x4 AT AC UP ->LONG BED<-
    Whole bunch of shit! $$$
    Bad gas....fuel filter....fuel pump...could be anything.
    Hank Heel and Joe23 like this.
  5. Feb 6, 2017 at 6:02 PM
    Hueston
    Hueston [OP] Member
    Hueston
    Ok I'll check the battery voltage and see what it reads
    No mods that required electricity
    If it's the oil it's the dealships fault, still using my free oil changes
    I also bought the extend bumper to bumper warranty for 7 years 100,000 miles so I'll probably be making a call to the dealership in the morning
    Joe23[QUOTED] likes this.
  6. Feb 6, 2017 at 6:24 PM
    Joe23
    if that's the case I'd say likely a faulty battery or shit petrol
    Hank Heel, dYL0n and shakerhood like this.
  7. Feb 6, 2017 at 6:27 PM
    Storman
    South Western PA
    I would guess bad gas too. Not sure the fuel filter change intervals of the truck or how many miles you have on it either. If you are under warranty, just take it to the dealer techs and let them figure it out. Good luck.
    Hueston[OP] likes this.
  8. Feb 6, 2017 at 6:30 PM
    Hueston
    Hueston [OP] Member
    Hueston
    Just hit 15,000 bought the truck last year in February so it's just now a year old. Thank you
  9. Feb 6, 2017 at 6:34 PM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    Use only top tier gas. Could be bad gas.
  10. Feb 6, 2017 at 6:51 PM
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    I'd think poor gas would be apparent in rough running and idling, not just starting.
    Battery is most likely culprit. I've had a couple die early. Very simple to check, dealer or any auto parts store should be able to load test it quickly. Dealer should warranty it this early if it's bad.
    shakerhood likes this.
  11. Feb 7, 2017 at 8:04 AM
    Hueston
    Hueston [OP] Member
    Hueston
    It's was a bad battery took to the dealership and they replaced it no questions asked.
    Thanks for everyone's help
  12. Feb 7, 2017 at 8:07 AM
    gpb
    Atlanta
    Glad it was simple and easy. ... and it's nice being right. : )
  13. Feb 7, 2017 at 9:31 AM
    Storman
    South Western PA
