Engine starting and turning off immediately
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tantrd08, Nov 27, 2019.
  1. Nov 27, 2019 at 1:53 PM
    Tantrd08
    Tantrd08 [OP] Active Member
    Nick
    08 trd off-road
    Rough country 3in lift/level Magnalfow off-road exhaust 265/75r16 Duratrac tires
    So I tried to sell my 2008 Tacoma today I’ve had it for about 3 years and it’s always ran perfect. The guy gets in turns the key and it started up and died immediately, happened 3 more times then I tried to get it started. Kept turning off immediately and sometimes it would just crank and wouldn’t fire up at all. I tried giving it some throttle and that seemed to do nothing. After about 15-20 minutes it finally started and then it was fine. Intake is good and fuel pump was running, any ideas of what this could be?
  2. Nov 27, 2019 at 3:22 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Possibly the Fuel Pump Resistor.
    IIRC, the resistor is by passed on starting and under high load or demand.
    The resistor is used while idling and under light or demand.
    If it starts and dies, and no codes are present, you could look there.
    Also, try running the truck a little hard, like 3,500 rpm or more.
    See if you have a loss of power. For example, as when passing some one.
    There could have been a number of other reasons, but this was one of the first things I thought of when I read the post. Especially if you have no codes showing currently?
    JC15Taco likes this.
  3. Nov 27, 2019 at 3:25 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    I think your Tacoma was getting separation anxiety because you're trying to get rid of him. I say, just keep him and get a second car.
    bubba swift likes this.
  4. Nov 27, 2019 at 3:28 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    This sounds immobilizer related to me
  5. Nov 27, 2019 at 4:41 PM
    FJBub
    FJBub Well-Known Member
    Doug
    2010 Tacoma PreRunner 2015 Tacoma TRD Off-Road 2008 V8 4Runner
    Do you have a chip in your key? Try the valet key. Had this happen in our 2010 Tacoma. Wife was amazed I was so smart.
    ETA: Just saw you got it running. Probably not chip in key. Carry on!
