Engine starting with key in door locks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NickMerai, Oct 2, 2014.
  1. Oct 2, 2014 at 8:38 PM
    NickMerai
    NickMerai [OP] Member
    Nicholas
    Guyana
    08 4wd tacoma sr5
    I have a 2008 toyota Tacoma with the normal lock, unlock and panic button alarm system. The alarm doesn't work from the remote so I basically lock and unlock my doors via the door lock. Of today I noticed the vehicle started when I insert the key and unlock then lock then the park light flashes and couple second after the engines starts and runs until I open the door and touch the brakes then it shuts off. May I remind you I didn't use the remote cause it doesn't work. Can someone please explain cause I'm a bit baffled.
  2. Oct 2, 2014 at 8:42 PM
    06 tacoma owner
    06 tacoma owner Well-Known Member
    Will
    Madisonville, KY
    2017 SR5 4x4
    Stock...for now
    The fuck? Thats weird!
  3. Oct 2, 2014 at 8:43 PM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    Did you buy the truck used? First gen or second? Factory remote? Sounds like it is equipped with a remote start system. The break is a standard safety cutoff on remote starts. In all my years and exerpience installing alarms I have NEVER heard of it starting with the door locks. Whatever is in there is wired funky or is going bad. Can you do it again and it works everytime you do it?
  4. Oct 2, 2014 at 8:44 PM
    NickMerai
    Nicholas
    Guyana
    08 4wd tacoma sr5
    Yea it's weird. When the engine does start it takes about 5 seconds then the park lights come on
  5. Oct 2, 2014 at 8:45 PM
    NickMerai
    Nicholas
    Guyana
    08 4wd tacoma sr5
    It's used and it's 2 gen. And yes everytime I try it , it starts and runs like normal.
  6. Oct 2, 2014 at 8:47 PM
    ProForce
    Anthony
    Alaska
    parking lights are also another standard feature on remote starts. its for safety and to help you locate the vehicle. Guranteed there is a RS installed. The question is why in the world does it start by cycling the door locks. Whoever installed it did something wrong lol.
    Look up under the dash for a black box hanging up above the pedals near the steering column with a TON of wire harnesses attached to it. Follow the harness about 6" and you should have 1 or more wires with a fuse on it. Pull them out and that will disable the alarm. This will prevent electrical issues in the future and the possibility of the truck going crazy lol
  7. Oct 2, 2014 at 8:49 PM
    NickMerai
    Nicholas
    Guyana
    08 4wd tacoma sr5
    Thank you will do. Another problem I carried the remote to change the battery and they did and said that it's not the remote because they changed the battery and nothing works. Is it possible the alarm system on the truck itself went bad and if so can it be repaired?
  8. Oct 2, 2014 at 8:49 PM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    hmmmm. Op how many times do you cycle your lock back and forth.
  9. Oct 2, 2014 at 8:51 PM
    NickMerai
    Nicholas
    Guyana
    08 4wd tacoma sr5
    2 or 3 times I would recycle it until it starts but once the vehicle is driven often in one day it's just 1 cycle and it starts.
  10. Oct 2, 2014 at 9:42 PM
    ProForce
    Anthony
    Alaska
    post a picture of the remote. and if you can find that black box it should have a model number or brand name engraved on it. Post pics and i can help you trouble shoot it. More than likely its an aftermarket remote for the alarm. Clearly the alarm works and has power. Either an important wire got disconnected or more likely the antenna is missing or unplugged. Maybe on accident maybe on purpose. If the antenne is plugged in then thats gonna be hard to toubleshoot without seeing it. But post what you can and ill see what i can come up with
  11. Oct 2, 2014 at 9:42 PM
    ProForce
    Anthony
    Alaska
    BTW, welcome to TW
  12. Oct 3, 2014 at 10:57 AM
    ranger098
    ranger098 Well-Known Member
    Brian
    Minnesota
    Welcome to TW. most likely you have whats left of a remote start/keyless entry system. You didnt get the remote for the aftermarket system. looking under the steering wheel should reveal an aftermarket box for a viper or other brand remote start system. Maybe you can leave everything hooked up and get a new remote, and have remote start! Bring it to a best buy or other car audio installer to confirm.
  13. Oct 3, 2014 at 11:23 AM
    HFDane
    HFDane Well-Known Member
    Dane
    Griffin, GA
    I've got s remote start on my Tacoma. Found it out by accident by clicking unlock 3 times in a row on my factory keyless remote.
    You might have to program your factory remote to your trucks keyless entry if changing the battery didn't work, there should be a write up on it, it's easy to do.
