Engine starts and shuts down
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Yakattack74, Jun 7, 2016.
  1. Jun 8, 2016 at 8:10 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
  2. Jun 8, 2016 at 8:11 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    You checked continuity (ohms) with power on the circuit? AFAIK you don't do that.
  3. Jun 10, 2016 at 9:22 PM
    westport toyota
    westport toyota Well-Known Member
    mine wont start once about every 4 months. it will start after ten tries. I was thinking it was the key chip because my key is so lose it can fall out while running. but the other day when changed my spark plugs, 2 of the coil bolts were totally loose , coil could move up and down or no grounding???
  4. Jun 27, 2016 at 5:39 PM
    Yakattack74
    Yakattack74 [OP] Member
    Brian
    08 Tacoma Dbl Cab 4x
    Custom Body Damage....Stabbed right fender with screwdriver....its still there
    Update....Good info fellas. I replaced the relays...no more trouble. Knock on wood. Thanks for the info. I also fixed my wifes town n country.....i went out for a carton of smokes and came back with a 2013 Corolla. Lol.
    NickofTime likes this.
  5. Jun 27, 2016 at 5:47 PM
    Drivesector
    Drivesector Well-Known Member
    TRD sport
  6. Jun 28, 2016 at 6:34 PM
    906UP
    906UP Well-Known Member
    U.P. of Michigan
    18 SR5 4WD, 17 Tundra CM-TRD
    And that good sir it how you keep a wife happy.......Well played!
  7. Jul 16, 2016 at 8:49 AM
    Yakattack74
    Brian
    The saga continues......the problem is back. so. I picked up the pump. I had trouble droping the tank so I removed the bed. Should have the tank back in today. While the bed is off I plan to look for a cpl noises back there. One is probably a brake drum. the other I hope to be a universal joint or center berring. Also gonna add D rings to each bolt n the bed floor for tie down points.
  8. Jul 16, 2016 at 8:49 AM
    Yakattack74
    Brian
    To right 906. Shes very pleased.
  9. Jul 16, 2016 at 8:53 AM
    ManBeast
    ManBeast Well Feared Member
    Zach
    Orange Park FL
    2015 DCLB:TOTALED-> 2014 4R TRAIL
    My gmc yukon has a built in security that has left me stranded when jumping the battery, it thinks im stealing the truck and proceeds to not let me start truck. Have to wait for about an hour for the "theif" to leave
  10. Jul 16, 2016 at 10:13 AM
    Yakattack74
    Brian
    that is another possibility
  11. Jul 16, 2016 at 11:30 AM
    Yakattack74
    Brian
    one bad berring in my rear most uni joint. not a single roller berring in the cup.
  12. Jul 16, 2016 at 5:57 PM
    Yakattack74
    Brian
    Well vibration and noise was fixed. With the new pump....she started up and ran. I shut down and tried to take it to top off the gas tank and it ran for 2 sec and sut back down....same crap its been doin. For now I am gonna asume its air in the fuel line. It runs like a raped ape now.
  13. Jul 16, 2016 at 6:20 PM
    supra90140
    supra90140 Well-Known Member
    telford pa
    08 dbl cab 4x4 lb trd sport speedway blue tow pkg
    weather tech floor liners
    I've had this issue a couple of times. It has acted up on me twice but hasn't in a long time
  14. Jul 17, 2016 at 3:12 PM
    Drivesector
    TRD sport
    If it turned on then off after disconnecting the battery that's normal. If it does it more than once it's not. It will start and stall 1 time usually after the battery is reconnected.
    That being said if it's still doing it and it's doing the starts for 2 seconds and stalls maybe look at the battery wire / connector supplying the ECM. Normally I wouldn't go there but you have no CEL, have replaced the fuel pump, and relay. Maybe there is a bad or corroded connection and the ECM looses its memory almost like you are disconnecting the battery all the time. It's a long shot but won't cost you anything to check.
  15. Jul 24, 2016 at 7:21 PM
    #35
    Yakattack74
    Brian
    Thanks Drivesector.I will check that once I can slow down. I am down to my last 5 days in the USAF and started back to school and helping tolaunch a business..Anybody need custom T-Shirts or vinyl decals?
