engine starts but shuts off
Discussion in '1st Gen. Tacomas (1995-2004)' started by tommy r, Dec 28, 2014.
  1. Dec 28, 2014 at 7:25 AM
    tommy r
    tommy r [OP] Member
    tommy
    florida
    97 taco
    so i replaced a blown head gasket on 97 taco. now when i start iit shuts back off aft min. but starts rite back up
  2. Dec 28, 2014 at 7:32 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Did you plug the mass air flow back in. It will do exactly what you're describing if it's not hooked up.
  3. Dec 28, 2014 at 7:39 AM
    tommy r
    tommy r [OP] Member
    tommy
    florida
    97 taco
    yes i did.and i kept getting code saying maf sensoreven replaced it with ne
  4. Dec 28, 2014 at 7:40 AM
    Bpassmore8
    Bpassmore8 Brian13DCSB
    Brian
    Vacaville, CA
    2013 Super White TRD Sport
    Debadged, N-Fab step bars, LED cup holder lights, LED dome and map lights, TRD stickers, HID retrofit (Morimoto Mini H1 6.0, BHLM, HomerTaco ghost raptor grill, OME 885s with 90021 up front, 60091 in the rear with trim spacer
    If it stays running if you keep the rpms up and if it will stay running after everything is warm check the idle air control valve. We see it all the time at work
  5. Dec 28, 2014 at 7:42 AM
    tommy r
    tommy r [OP] Member
    tommy
    florida
    97 taco
    after a few times of starting i can get it to run
  6. Dec 28, 2014 at 7:44 AM
    Bpassmore8
    Brian
    Vacaville, CA
    check that then. Some people call it an idle speed control valve
  7. Dec 28, 2014 at 7:53 AM
    tommy r
    tommy r [OP] Member
    tommy
    florida
    97 taco
    ok ill check. thanks
