Engine starts then stalls
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Windguy, Dec 14, 2014.
  1. Dec 14, 2014 at 2:33 PM
    Windguy
    Windguy [OP] New Member
    Peter
    Ontario Canada
    09 Tacoma
    I have a 09 Tacoma with a 2.7, sometime when I start it up it will run for a second then quit the only way I can restart it is to remove the positive batterie cable and reset something. This has happened 3 times in the last several months any ideas what it could be
  2. Dec 14, 2014 at 2:38 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I'm hearing the Crank Position Sensor would be a good place to start but I could be wrong.
  3. Dec 14, 2014 at 4:57 PM
    Drivesector
    Drivesector Well-Known Member
    TRD sport
    Are you always using the same key? Try a different one. Sounds stupid but had a similar issue with a vehicle and the transmitter in the key was going bad. Any codes coming up? Check engine or security light?
  4. Dec 14, 2014 at 5:05 PM
    Taco'09
    Taco'09 Well-Known Member
    Have you put a scan tool on it to see if there is a pending code?
  5. Dec 14, 2014 at 6:50 PM
    Windguy
    Peter
    Ontario Canada
    09 Tacoma
    I have not scanned for codes but will and will also switch keys and see if it happens again thanks
  6. Dec 14, 2014 at 11:09 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I don't think the 2.7 Liter models have an engine immobilizer at least in the USA. How about Canadia?
  7. Dec 15, 2014 at 3:45 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    I know if you disconnect the 4.0 battery cable it will start then stall. But it will only do it once. Not sure if the 4 bangers do the same thing
  8. Dec 18, 2014 at 4:57 PM
    Drivesector
    TRD sport
    You figure it out?
  9. Dec 18, 2014 at 5:15 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    I suggest you get any codes you can. IF no codes I wonder of the Computer got hung/stalled?
  10. Dec 18, 2014 at 7:47 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    I'd suggest cleaning the MAF sensor and swapping the fuel pump relay if you don't have it resolved yet.
  11. Dec 18, 2014 at 7:52 PM
    adamr94
    adamr94 Well-Known Member
    Adam
    NC
    06 Regular Cab 4x4
    correcto, all 4 cyls don't have that.
  12. Dec 18, 2014 at 10:50 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    Immobilizers are standard equipment in Canada, in compliance with federal law.
    9. [EIS] ELECTRONIC IMMOBILIZATION SYSTEM - Every passenger vehicle, multipurpose passenger vehicle, truck and three-wheeled vehicle manufactured after September 1, 2007, with a Gross Vehicle Weight Rating (GVWR) less than 4,536 kg (10,000 lbs), except an emergency vehicle or a walk-in van, must be equipped with an electronic immobilization system, as per the requirements of CMVSS 114 - Theft Protection.
  13. Dec 19, 2014 at 2:28 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Canadia is getting into the Nanny Business too then. [​IMG]
  14. Dec 19, 2014 at 3:22 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Try swapping out the fuel pump relay. Had something like that going on with my Tundra. If your gonna throw parts at it, throw cheap stuff first.
  15. Dec 19, 2014 at 5:56 AM
    Canufixit
    New England
    The OPs description leans me towards an electrical issue ??? Loose connector /connection? Frayed wire, Crossed wire, Etc. ????? It runs then stops suddenly then mysteriously runs fine .... battery almost dead ??? Alternator going bad /check charging (possible shorting bad diode)?
  16. Dec 19, 2014 at 7:13 AM
    landphil
    BC, Canada
    Tundra 5.7 mod
    Oh hell, we've been there a long time. :mad:
  17. Dec 19, 2014 at 8:57 AM
    Supramacy
    Supramacy Well-Known Member
    For sure not an immobilser issue because the truck would not start at all. It will crank but will not start. Definitely check for codes and if possible check the data list while starting to see if there is a sensor signal missing. You need a pretty good scan tool though.
