Engine Stops Responding and Throttle Gets Tight, Ideas?
Discussion in '1st Gen. Tacomas (1995-2004)' started by psu75, Feb 22, 2021.
  1. Feb 23, 2021 at 8:58 AM
    #41
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    These days, it'll probably take less time for Amazon to ship a code reader to you than to drive down to the store and have them do it, lol
  2. Feb 23, 2021 at 8:58 AM
    #42
    psu75
    psu75 [OP] Well-Known Member
    Krista
    TEXASSS
    2018 Crewmax Tundra 4x4 TSS
    No, we were going to keep it because we still use it for camping trips for just us two. Not sure what else to say.
  3. Feb 23, 2021 at 9:02 AM
    #43
    psu75
    Krista
    TEXASSS
    Friday...
    jbrandt[QUOTED] likes this.
  4. Feb 23, 2021 at 11:21 AM
    #44
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    @psu75 I've skimmed through the thread but wanted to touch on this as I've read up on some of this.
    It could be one of the sensors (although it should show codes for it). check all the connections on the TB, make sure to unplug the APPS (front sensor) and the TPS (rear sensor) and see if any corrosion on pins or contacts. worth a shot. Limp mode is basically the ECM not receiving the correct parameters from the process of "hitting the gas" and thinking something is wrong.
    the way it usually works (paraphrase of course):
    push pedal -> APPS reads -> sends data to ECM -> ECM send command to TB motor -> ECM asks TPS to report back, are we "all good"? -> TPS gives a thumbs up -> happy go lucky
    all within .000673 seconds :D
  5. Feb 23, 2021 at 12:01 PM
    #45
    psu75
    Krista
    TEXASSS
    This is extremely helpful. I've ordered the FIXD tool which arrives on Friday. In the meantime, I will do some Googling to find out how to do the troubleshooting steps you mentioned.
  6. Feb 23, 2021 at 12:54 PM
    #46
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    I have debated the same thing in the past but.... The 1st gen Tacoma is one of the easiest vehicles I have ever worked on. It almost reminds me of working on my Suzuki DR650. Just dead simple and I can save a ton of money tearing it apart in the garage (or driveway). I just can't get rid of this ol' bitch. lol
  7. Feb 23, 2021 at 1:07 PM
    #47
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    just be advised, the simple Bluetooth devices can't always see everything. mine can read codes and some sensors but most is beyond the scope of the simple plug-in ones
  8. Feb 23, 2021 at 1:14 PM
    #48
    psu75
    Krista
    TEXASSS
    Ahhh! I have a DR200!! My father in law has the 650. Awesome bikes...except right now my 200 isn't getting gas for some reason. Pulled fuel line, checked air filter, etc. Guess I'm going to have to pull the carb :rant: But that's a story for a different forum (ADV).
    Xbeaus[QUOTED] likes this.
  9. Feb 23, 2021 at 1:19 PM
    #49
    psu75
    Krista
    TEXASSS
    Roger that. If nothing shows up, I'll bite the bullet and take it Toyota or Bert's.
  10. Feb 23, 2021 at 1:21 PM
    #50
    Toyko Joe
    Toyko Joe Here for the pictures
    Fuel filter or fuel pump going bad.
  11. Feb 23, 2021 at 1:21 PM
    #51
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    @psu75 When it went into limp mode did you notice the ABS light come on as well? If so It may be the p0333 or p0334 knock sensor code. If it gets cold at night you may get small rodents sleeping in-between the cylinder heads and they love to chew on the knock censor wires.
  12. Feb 23, 2021 at 1:22 PM
    #52
    psu75
    Krista
    TEXASSS
    No. No ABS light.
  13. Feb 23, 2021 at 1:34 PM
    #53
    Tour991
    James
    South Reno/Tahoe
    Take a look under the intake manifold if you can, look for signs of creatures, that also may help you track down the problem.
  14. Feb 23, 2021 at 3:25 PM
    #54
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    @psu75
    One other suggestion, you may want to either change the name of your thread, or start a new one with something like "Engine Stops Responding and Throttle Gets Tight, Ideas?". Some of the folks who have good diagnostic experience may not look at your thread thinking you are only looking for advice about selling.
    psu75[OP] and frizzman like this.
  15. Feb 24, 2021 at 6:33 AM
    #55
    psu75
    Krista
    TEXASSS
    Thanks! Done.
    Wsidr1[QUOTED] likes this.
  16. Feb 24, 2021 at 6:33 AM
    #56
    psu75
    Krista
    TEXASSS
    No critters :goingcrazy:
  17. Feb 24, 2021 at 9:03 AM
    #57
    Wsidr1
    Indiana
    Good luck with replies.
  18. Feb 24, 2021 at 9:05 AM
    #58
    Imfeelinrisky
    Imfeelinrisky I dream of 200hp to the wheels
    Houston
    2002 Tacoma Double Cab
    I'm a little late, but what area in Texas are you in? You could always ask around in the Texas section of TacomaWorld and see if someone can recommend a mechanic. I know of a couple in Houston that I'd definitely recommend, and I'm sure plenty of other folks know of some trusted and reliable shops. If nothing else maybe you could call into one and see if they give you any suggestions on where to start looking.
    Either way, good luck!
  19. Feb 24, 2021 at 9:12 AM
    #59
    psu75
    Krista
    TEXASSS
    Thanks! I did post in the San Antonio section, got a few suggestions.
